FZ750 Carburetor - How did this happen
skyehigh
PostPosted: 14:18 - 28 Jul 2019    Post subject: FZ750 Carburetor - How did this happen Reply with quote
On my way home on Friday Evening when my 2MG FZ stated losing power and running really roughly. Limped home and on Saturday I decided to check the carbs out as I felt it was a fueling issue. As soon as I removed the bank I heard a rattle and when I removed the float bowl cover I found this bit inside (see pic busted1) - there was just enough of the remaining bit protruding to allow me to use a engineering pick to rotate it and remove it. I decided to check the other three carbs and although all the others were intact I decided to remove them and check them - sure enough another one sheared off as I was cleaning it! I have a spare set of carbs so was able to replace the broken ones. OK I know that they are probably original to the bike (28 years) so I guess its just down to age related issues but wondered if anyone has had anything similar happen?
Also any ideas to replacement suppliers - eBay doesn't seem to have anything
PostPosted: 14:27 - 28 Jul 2019    Post subject: Reply with quote
Not sure, brass is pretty weak and if it was made with a crystalline structure, it could have fractured along the edges of two crystals.
For parts I suggest Allens Performance:
https://www.allensperformance.co.uk/
skyehigh
PostPosted: 15:21 - 28 Jul 2019    Post subject: Reply with quote
Many Thanks - will contact them
PostPosted: 16:19 - 28 Jul 2019    Post subject: Reply with quote
That is weird, doesn't look like a stressed part at all and brass should be pretty impervious to chemical damage. No witness marks on the flats implying overtightening either.
Second vote for Allens.
skyehigh
PostPosted: 19:37 - 28 Jul 2019    Post subject: Reply with quote
Yep - very strange and the second one that sheared did so in almost exactly the same place!!!!
PostPosted: 20:13 - 28 Jul 2019    Post subject: Reply with quote
I wonder if there was some odd electrochemical thing going on. It's unusually close to the end of the stainless float pivot pin.
someone
PostPosted: 21:57 - 28 Jul 2019    Post subject: Reply with quote
looks like a brass plated zink to me .
zink is very common in automative industry .
cheap very brittle and ugly , but usully its alumnuim plated zink to cover its nasty core
a machine shop can produce a better stanless steel or brass part .
i highly recommend getting a machine shop produced part if its a critical part to you , those guys take pride in there work better than a casted oem or worse aftermarket part
EJ6 FOREVER AND FOREVER A HUNDRED YEARS EJ6.
Easy-X
PostPosted: 23:37 - 28 Jul 2019    Post subject: Reply with quote
Looks like brass to me! Most cheap zinc alloys are usually silver to copper coloured - looks like brass throughout the shear.
The last post was made 6 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 56.52 Kb
