Kawasaki gpx750r timing
Fumble
PostPosted: 12:10 - 01 Aug 2019    Post subject: Kawasaki gpx750r timing Reply with quote
Has anybody got one of these who could confirm what timing mark should be used on the crank when refirting the camshaft, the picture in the Haynes manual is rubbish and there is a F and a T next to each other so which one to use?
bikenut
PostPosted: 12:50 - 01 Aug 2019    Post subject: timing Reply with quote
F usually means "fire" which will be before TDC minimum ign advance....
T usually means "Time" or TDC ( top dead centre, the highest point of piston stroke towards the cylinder head ).
You know which are the correct cam timing marks on the cam sprockets are and any cam chain droop and number of chain pins??
nuts about bikes
Bhud
PostPosted: 13:39 - 01 Aug 2019    Post subject: Reply with quote
You set the engine to TDC by lining up the T mark. This is the one you use when putting the cams back on.
You adjust the ignition timing rotor so that you see the 'F' through a little window when you're setting the timing with a test light.
Do you have a Haynes manual? Read through the relevant section a few times until you understand how it's all supposed to work. It will save you from breaking something.
The last post was made 6 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.8 - MySQL Queries: 13 - Page Size: 34.78 Kb
