Derestriction, metal washers?
mr motorbiker
PostPosted: 21:17 - 26 Mar 2005    Post subject: Derestriction, metal washers? Reply with quote
I need all the help i can get on derestricting my zxr400L.
its been retricted by metal washers in the carb.
can anyone give a step by step guide on their own experiences. where to locate the carb, what tools i need, can it be done by a mechanical novice. how to remove the carb. any site that you know of (i cant find anything of any use).
cheers for any help at all.
Jrod
Page 3 Girl
PostPosted: 00:26 - 27 Mar 2005    Post subject: Reply with quote
Right, Take off the tank, then you will see the airbox. You need to take this off, There are 2 little covers on the airbox which you need to remove to get to some bolts that need undoing to remove the airbox. Once thats off you will see the carbs.
Look to the bottom of the carbs and you should be able to see where they joing onto the engine, they go into the inlet rubbers which has clips on.
You undo the screws that are on these clips. Once undone pull on the carb and it should pop out.
You will now see the washers, there are 4 of them one in each inlet. There are 2 bolts on each inlet holding the washers.
Undo the bolts then remove the washers.
Do the bolts back up making sure everything is the same way round.
When you push the carbs back in and tighten the screws on the clips that hold them they HAVE to be the same way or they may fowl the carb and be dangerous.
Thats pretty much all there is to it. Thumbs Up
instigator
PostPosted: 00:51 - 27 Mar 2005    Post subject: Reply with quote
Precisely what I was going to say. Thumbs Up
Jrod
Page 3 Girl
PostPosted: 01:12 - 27 Mar 2005    Post subject: Reply with quote
You know I said it better. Mr. Green
mr motorbiker
PostPosted: 14:48 - 27 Mar 2005    Post subject: Reply with quote
thanks a lot mate. Very Happy
Jrod
Page 3 Girl
PostPosted: 17:29 - 27 Mar 2005    Post subject: Reply with quote
I spent ages looking for someone to help me do it but noone did, I just went at it on my own. You've got an advantage now. Wink Thumbs Up
The last post was made 21 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 49.04 Kb
