| Easy-X |
 Easy-X Super Spammer
 Posted: 12:17 - 02 Aug 2019 Post subject: Idea for Honda OBD2 Project |
So I looks like I'll be riding about on a Honda Rebel by next week. Hmm... not much I'll need to do to a new bike surely?
Hehe, well not mechanically but after test riding and reading reviews most ppl cite the lack of a gear shift indicator (I iz n00b) and rev counter as being somewhat... annoying. I notice that you can plug things into the OBD2 plug under the seat like a shift indicator or a rev counter. No idea what you do if you want both!
In an ideal world I think I'd like a rev counter, shift indicator and coolant temp readout... maybe a clock, and so on.
I turned up this:
https://gonzos.net/projects/ctx-obd/
Where a guy interfaces a Raspberry Pi to a CTX-700 but he's got like web interfaces to smart phones and all sorts!
I'm thinking it would be more flexible to hack an off the shelf Bluetooth OBD interface to work with the red Honda plug and bolt a cheap Android phone onto the handlebars with something like the Torque app.
Anyone had any luck doing such a thing? ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| P.addy |
 P.addy Red Rocket
| redeem ouzzer |
| ThatDippyTwat |
| pepperami |
 pepperami Super Spammer
| Teflon-Mike |
 Posted: 14:31 - 02 Aug 2019 Post subject: |
My Cota has no instruments. The Seven-Fifty's speedo cable snapped probably a deacade ago... I 'think' I stuck a new one on a bits order from DSS some years back, but I have never really missed it... or got a speeding ticket.. so never 'really' been an imperative.
Judge speed by other traffic and wind in your face.
Judge revs by how load the engine be
Judge coolant temperature? Err, yeah, this is the UK... listen to the weather forcast!
Indicator repeaters? Cant you actually see the lamps from where you sit?
Gear Possition? WTF? Need acceleration, change down! If not, see comment vis speedo, and or change up! Onlyt the Neutral Warnbing lamp is moderately halpful, and oft not that useful, especiallu on dee Italian Traactor!!!
Oil Pressure Warning, might be the most useful, but even there... had the sump-plug unwind (found it on the collector!), once, but even that almost total los of lube didn't make lamp come on... swuirming about of back tyre was more alerting!
What else I got on the dash? Odometer and trip? Err, see comment vis speedo cable. Moderatly useful if they worked for keeping track of fill ups and oil-changes.. Ignition/Alternator? Probably the most udeful bit of instrumentation... but then only if I have taken the key out of the ignition barel, without swithing ign 'off' 'cos lock worn!
You can live without evenb the most BASIC crap on an old bike... if you want all that chit.... take the effin car, and the missus to yell at you you are too close, to fast, too 'wrong'... whole point of a bike is to leave ALL this chit behind NOT take it with you.... loose the dumb-phone whilst you are at it... too
Take a paper map, or get lost and call it an adventure/exploring.... THAT is what a bike is all about.... NOT how many damn APPs you wired into! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Robby |
 Robby Dirty Old Man
| Ste |
 Ste Not Work Safe
 Posted: 15:30 - 02 Aug 2019 Post subject: |
Pro tip: if because reasons you want a rev counter then the best solution is to buy a bike that has a rev counter.
Gear shift indicator?
Coolant temperature?
Clock? Leave earlier.  |
| G |
 G The Voice of Reason
| Easy-X |
 Posted: 18:05 - 02 Aug 2019 Post subject: |
TBH none of the things cited would be looked at beyond a cursory glance from time to time it's more the challenge of making sh*t work. I could spend many hours constructing a tiny little Arduino LCD thingy and then probably never look at it on the bike!
I had a rev counter on the Superlight and the only time I looked at it was as a sanity check when the throttle seemed to stick open. (Cleaned the throttle body and it was fine after that.) Again with the shift light I added it was a sanity check pulling away "hang on, am I in the wrong gear?" 3 on display "...yes I am."
All just a confirmation of expected stupidity. Having said that a warning light that the coolant temperature was well up could actually save some pennies in the long run but even so that's a crutch for not checking over the bike properly before heading out.
Calculating MPG and expected range left in the tank would also be a neat trick but as my commute is ~15 miles - a little pointless.
Apologies then, I shall try and dial down the autism  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| stevo as b4 |
| Bhud |
 Bhud World Chat Champion
| Easy-X |
| Ste |
 Ste Not Work Safe
| Easy-X |
 Posted: 00:57 - 03 Aug 2019 Post subject: |
"...and at 12,000 rpm the bike is for rectal use only."  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 15:41 - 03 Aug 2019 Post subject: |
Easy-X eh?
hmmmmm
Y'know?
Cant help thinking Easy-X sounds like some sort of
laxative or rectal lubricant.
Hey, if your into that sort of thing that's fine
This is BCF we dont judge
but if you want roll the dice on another moniker that's fine too. ____________________ bikers smell of wee |
| Sister Sledge |
 Posted: 18:30 - 03 Aug 2019 Post subject: |
| WD Forte wrote: | Easy-X eh?
hmmmmm
Y'know?
but if you want roll the dice on another moniker that's fine too. |
It's not just me!
I was thinking this cool lad who's a cowboy at heart but a real stud with the girls. Decides to make his fortune and heads to the big city. Cinema scene follows!
Why the name change? Surely something like 'More Honda' would better?? ____________________ CCM 404 DS |
| Easy-X |
 Posted: 20:21 - 03 Aug 2019 Post subject: |
The number plate ends "EZX" I thought it had a nice ring to it
Anyway, no one was taking me seriously with the previous moniker so I thought it was time for a re-branding exercise  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Easy-X |
 Posted: 20:23 - 03 Aug 2019 Post subject: |
hmmmmm
Y'know?
And for some reason ppl previously associated me with arseless chaps! ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| WD Forte |
| sickpup |
 sickpup Old Timer
| Easy-X |
| A100man |
 A100man World Chat Champion
 Posted: 17:11 - 05 Aug 2019 Post subject: |
| Easy-X wrote: | There is only the one type sold in the UK: CMX 500
(not one of the old 250cc ones if that's what you were wondering.) |
Christ! Looks like the type of bike a bloke wearing 'arseless chaps' would ride..
https://www.honda.co.uk/content/dam/central/motorcycles/street/cmx500-rebel-2017/Honda-CMX500Rebel-Overview05-1x1.jpg/_jcr_content/renditions/c2.jpg ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| Easy-X |
| stevo as b4 |
 Posted: 18:19 - 05 Aug 2019 Post subject: |
That doesn't look too bad to me tbh!
1, No chrome
2, fairly understated and with a parallel twin presumably quite revvy motor like the CBR500.
3, no silly ultra high chopper bars, and no daft side mounted number plate.
It's a far better looking bike than something like a Ducati Diaval IMO, and it doesn't look like it's sacrificing too much comfort and geometry and handling in the name of style.
Might be a decent little bike, if there's a reasonable amount of ground clearance too?
Then again I haven't said it looks like an assless leathers bum sex queers convention, so I guess I must be the most boring sad cunt in the world for not doing so? |
The last post was made 6 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
