Rear shock absorber adjustment for pillion?
Guernsey
PostPosted: 12:13 - 04 Aug 2019    Post subject: Rear shock absorber adjustment for pillion? Reply with quote
Hello peeps!
I've recently passed my motorcycle cat A test and looking at practising to take a pillion.
I've looked up some videos (along with the pillion) and checked the manual.
I need to adjust the rear suspension to account for the extra weight. Unfortunatly the manual does not give any indication to what you should set it as.
It can go between 1-8 with the default recomendation as two, both me & the pillion weigh 80KG each, what setting should I have it on?
Thank you
It's a Honda CB300R 2019 model
yen_powell
PostPosted: 17:09 - 04 Aug 2019    Post subject: Reply with quote
Sit on the bike on your own, look at something in the rear view mirrors. Sit your pillion on after adjusting, try and get it so you can see the same view in the mirrors. You're just trying to keep the bike the same level as when you're on your own.
XT1200Z and a DR350 in bits
jaffa90
PostPosted: 17:29 - 04 Aug 2019    Post subject: Reply with quote
Good advice but chock the side stand to near upright with both feet on the pegs and then with 4 feet on the pegs.
Also the back tyre may need 46 psi or more.
MCN
PostPosted: 19:08 - 04 Aug 2019    Post subject: Reply with quote
Just a musing...
Does anyone ever adjust the tyre pressures of the car when more than two passengers and or some luggage is being carried? 🤔
No fukir really cares. 🤣
Easy-X
PostPosted: 00:14 - 05 Aug 2019    Post subject: Reply with quote
Only if I'm going on a long run (back to Cornwall for example) would I bother checking the tyre pressures.
The last post was made 6 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 43.43 Kb
