| andy46 |
 andy46 Derestricted Danger
 Posted: 11:30 - 07 Aug 2019 Post subject: chinese 125 no spark please help |
I have a dayang 125 which looks to be based on the honda cg 12v electric start.
It was running fine but wouldn't start on sunday morning. Investigation showed either no spark at the plug or an intermittent thin yellow spark which has now dissapeared completely.
So far I have used the haynes chinese 125 manual and a multimeter to check out the ignition system.
Ignition coil primary winding shows 1.8 ohms (haynes says 0.5 to 5)
secondary winding shows 4.2 Kohms (haynes 3 to 12)
plug cap shows 5.28 Kohms (haynes "around 5")
There are no blown fuses, all relevant connections have been checked and cleaned, I am using a known good sparkplug which is properly grounded.
haynes now moves onto pick up coil:
testing accross 2 wires from pick up coil (blue/white & green/white) shows 142.6 ohms (haynes 15 to 150). I tested this at the connector to the stator and at the connector to the cdi - same result.
At this point haynes suggests a physical exam of the pick up coil which I did. I don't really know what to look for but there were no loose wires, all soldering looked OK and no obviously burned out bits.
It isn't possible to check the clearance between the pickup coil and the flywheel but both can only be fitted in one position, they were and are secure.
haynes then suggested a cdi fault with no way to test other than to try a new one, so I did - didn't fix the problem.
other tests I have done show continuity from the yellow/black wire at the cdi to the ignition coil, 56 to 60 volts AC from the red/black wire from the ignition winding on the stator (when cranking).
Also I have continuity to ground from the black/white wire at the cdi when the ignition is off - this dissapears when the ignition is switched on, a similar test shows the kill switch to be working as it should.
I have removed and dismantled the ignition and kill switches, cleaned, reassembled and refitted, both appeared OK.
The bike is not fitted with a side stand switch and I can find no evidence of one having been previously removed.
So after doing all this I thought "once you eliminate the impossible, whatever is left, no matter how improbable is what has to be" So i should order another new cdi !!
OR I could ask for some help on a internet forum, so what have I missed? |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 12:27 - 07 Aug 2019 Post subject: |
You HAD a spark, just not a very beefy one, which sort of suggests that the electrics are prfobably OK... there's only the one winding in the stator to makle electric,. then the trigger for the CDi and the CDi, then the coil and the Plug itself.
So how old shagged be the plug? That's where I would start.
CDi's tend to be prttrt reliable, ditto statpors; coiuls can be a bit iffy occasionally.. I think I have had to replace ONE on one of my bikes in forty years..... clean up the earth contacts and wipe down the HT leads, replace them if you have to replace anything as first course.... after the spark plug...
Amazing how many presumed problems go away with a new plug... really is....
After that, CG ignition has make to kill off circuit,,,,, if you pull black-white wire froim the ign CDi, it sgould isolate ALL the kill switches, to eliminate all thiose possible probls nd potetial short circuits.... which are probably more likely than a fault ion the stator or CDi or coil.... so ~IF bike ruins with CDi kill wire isolated, connect one switch in turn and kook-see which one makes problems.... side stand switches are notpropuse, most oft for numpty owners tryting to by-pass them... but still....
Work systematically and logically, and remember, sparks are self exited, itrs a sumple magneto based system, its actually quite hard to turn the sparks off, so if you dont get'em, more likely something wromg in the way you are looking, than the electrics.. so look for fault in your methodology before the bikes electrics... and top tip here is to use car jump-=lead to ensure good earth for the spark-plug (As well as good new spark-plug?!)
And domnt 'sixate' on the sparks: - many reasons a bike wont rund, lack or weak sparks is but one; good odds on CGT type motor that the tappet clearances have never been tioched or have, and either way the valves are either never opening or never closing and or timing is well out, head gaskst could be gone, and cpmpression down and or the carb has been cleaned to death... of ALL the possoble reasons bike might not start, not making sparks is actually the least likely IME... and how you trying to make sparkss Good bet by spinning mpotor up on the strarter.... and remember its self exitred sparks, they dont come out the vattery,. so IF the motor no spin so quick, you no get strrong or any sparks.... try looking at the starter, cleaning up the brushes and solenoid, fitting new battery so that it does spin motor over fast enough to make beefy sparks.....
You could and are likely to be chasing a red herring, with the wrong kind of fishing fly! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| WD Forte |
 WD Forte World Chat Champion
| Easy-X |
 Easy-X Super Spammer
 Posted: 13:48 - 07 Aug 2019 Post subject: |
My bet is the spark plug coil. Regardless of the "normal" readings you get it might still misbehave when you attempt to put it into operation.
Shouldn't cost much. Also, did you buy an "ordinary" CDI or some fancy "racing" one 'cos from personal experience I know the latter can be a waste of time  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| andy46 |
| WD Forte |
 Posted: 17:25 - 07 Aug 2019 Post subject: |
Don't get confused
AC from the source coil (open circuit) and pulsed DC after the CDI
the magnets a possibility but its usually windings.
Had to fix lots of bad windings but dont ever recall finding stator magnets
so bad as to need replacement.
The AC from the source coils is rectified in the CDI box to charge up a capacitor until a pulse from the trigger coil
turns on an SCR which 'dumps' the caps energy to ground collapsing the coils EMF and so on.
Tldr:
The point is, low energy in = low energy out
I've rewound some myself usually for the lads bikes but they're so damn cheap I wonder if its worth it
the one below for instance is only £23
https://www.ebay.co.uk/itm/125cc-Motorcycle-Stator-for-Chinese-CG125-OHV-156FMI-157FMI/161163725711?epid=18003267730&hash=item25861b4b8f:g:kkIAAOxyLN9SmeLk ____________________ bikers smell of wee |
| andy46 |
| andy46 |
| Easy-X |
 Posted: 16:47 - 09 Aug 2019 Post subject: |
Glad you got it running  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Tankie |
 Tankie Crazy Courier
 Posted: 21:34 - 09 Aug 2019 Post subject: |
A good informative thread, with a good conclution
I've had cdi's destroyed by kill switches before, going short, so maybe a coil going short will make the cdi work too hard and pop! ____________________ Always learning, everyday is a school day |
The last post was made 6 years, 247 days ago. Instead of replying here, would creating a new thread be more useful? |
