NSR 125 problem 8000rpm
RSD00
PostPosted: 15:34 - 07 Aug 2019    Post subject: NSR 125 problem 8000rpm Reply with quote
Hi, i recently buy an NSR 125 (ZDCJC22B) - i think french Doh!
I changed oil,air filter but it works perfect untill 8000rpm at 8000rpm it stucks and doesn't go up to 9-10-11k rpm.
Goes max 80km/h.
What should i do ? Can you give me some advice or some steps to follow to solve my problem.. ?
RSD00
PostPosted: 16:07 - 07 Aug 2019    Post subject: Reply with quote
i will check that, but alains in the last topics said something about an "red shunt" under seat Confused
i think there is an german limiter at 80km/h
Easy-X
PostPosted: 19:00 - 07 Aug 2019    Post subject: Reply with quote
French bike? German limiter?! Roll on Brexit Laughing
RSD00
PostPosted: 19:35 - 07 Aug 2019    Post subject: Reply with quote
I saw in one post the french bikes got limiter like german bikes ..
Easy-X
PostPosted: 20:04 - 07 Aug 2019    Post subject: Reply with quote
Yeah, just having a bit of fun Wink 80kph (50mph in old money) does sound a bit tame though Sad
What year is it?
RSD00
PostPosted: 06:13 - 08 Aug 2019    Post subject: Reply with quote
1998 year
PostPosted: 12:14 - 08 Aug 2019    Post subject: Reply with quote
When you say changed the air filter what exactly do you mean? Ripped off the airbox and replaced it with a pod? Or replaced the standard filter with another OEM standard air filter?
stevo as b4
PostPosted: 16:31 - 08 Aug 2019    Post subject: Reply with quote
I'm no NSR expert, but firstly the OP needs to decide if the bike is speed limited by a fault/wear, or if its by a restriction.
I remember Alains posting up about all kinds of different NSR specs, and particularly different CDI boxes too.
If the bike is limited to 12/15bhp it should still accelerate past 50mph with ease. If the bike has a fault or wear that's reducing power very significantly then it might be down on power enough to only reach 50mph. It'd have to be pretty knackered andow on compression to do this I would have thought?
I don't think Honda used speedo restrictions like a Reed switch for example, and the NSR250's are more advanced in that the ignition system is linked to a gear position sensor. This allows them to really only restrict the bike in mph, by messing with the ignition timing or rev limiting in say the top three gears.
I don't know if the 125 NSR is as advanced as that, but it'd be worth checking.
If I was OP however, I'd be giving the bike a full detailed service and possibly an engine rebuild depending on the compression reading etc. Then I'd want it on a dyno to see if it's fueling correctly and if the power output is in the right ball park which should be 20 something bhp at the wheel.
If I had any doubts then about the CDI being either faulty or having a restriction built in, then I'd go for an aftermarket CDI and get it set up correctly. OK dyno time and programmable ignitions aren't cheap, but if I wanted a pride and joy 125 to run as well as possible it'd be worth it IMO.
RSD00
PostPosted: 14:35 - 09 Aug 2019    Post subject: Reply with quote
I changed air filter with a new one standard, it not revs after 8000rpm doesn t matter if is in 1-2–3-4-5-6 .. in 8000rpm he locks there and misfire between 7500-8000
Idk when was the last time when was changed top end
Tankie
PostPosted: 20:46 - 09 Aug 2019    Post subject: Reply with quote
Is the exhaust clear of coke? restriction of revs is a sign of carbon build up, check the exhaust port in the cylinder and then check the rest of the system
Ice Burger
PostPosted: 17:55 - 13 Aug 2019    Post subject: Reply with quote
Check the RC valve, it's a device that's supposed to kick in at higher revs and change the mixture to achieve a taller rev range. Maybe yours istnt working properly or not doing anything.
https://en.wikipedia.org/wiki/Two-stroke_power_valve_system#Honda_RC-Valve
alains
PostPosted: 09:36 - 15 Aug 2019    Post subject: Reply with quote
for everybody and especially for you
french bikes are not limited at 50 mph
some swiss bikes have a limiter with a red shunt on the valves controler
german bikes have a CDI CI626A in order to limit at 50 mph for youth
but as french bikes have CI639 a special wiring must be fit to obtain the same result as above
as i dont like DIY for the wiring , i suggest to change the harness
PS i think our young fellow is a bit hard to convince Evil or Very Mad
Ice Burger
PostPosted: 15:59 - 18 Aug 2019    Post subject: Reply with quote
This might sound really obvious but check the choke isn't left on.
alains
PostPosted: 17:31 - 18 Aug 2019    Post subject: Reply with quote
that's a comment from a guy who knows nothing ! Shocked
The last post was made 7 years, 89 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 97.93 Kb
