XSR900 Chain Adjustment
Jon-W
PostPosted: 17:51 - 09 Aug 2019    Post subject: XSR900 Chain Adjustment Reply with quote
Hi all,
Well, this could really apply to any bike and I am sure there are many differing opinions on it. I have just gotten around to adjusting the chain tension on my XSR900 (only had it a month or so). Now, out of curiosity what are peoples opinions on the importance of getting chain tension absolutely correct (I am a stickler for detail, unfortunately, so these sorts of things bug me). I've used the notches on either side of the swing arm as a guide for getting the alignment right, but I've also measured from the back of the adjuster block to the end of the swing arm (as per the pics) and found when the measurement is the same, the notches on either side don't quite line up, maybe half a notch out.
What is the consensus about what is more accurate?
Riejufixing
PostPosted: 18:38 - 09 Aug 2019    Post subject: Reply with quote
I don't trust marking on the swinging arm. Assuming the graduations are actually even each side, I treat them as a rough guide only, after looking at them and noting positions after otherwise adjusting alignment. I use a straight edge for aligning wheels.
As for tension, I try to get the manufacturer's recommendation. It is absolutely necessary to check the chain in various positions, using the tightest position (if there is one) for adjusting the tension, and I'd rather had the chain a fraction loose than a fraction tight.
Easy-X
PostPosted: 19:57 - 09 Aug 2019    Post subject: Reply with quote
Surely the important thing is to get the wheel aligned straight with the rest of the bike? The marks are just a starting point.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:28 - 09 Aug 2019    Post subject: Reply with quote
One of the advantage of a single sided swingarm with excentric adjustment is there's almost no way of getting the alignment wrong.
Triumph Sprint ST 1050
jaffa90
PostPosted: 00:56 - 10 Aug 2019    Post subject: Reply with quote
Looking at the picture of the bike it reminds me of a trail type bike (i`ve had many) with a long swing arm travel. So i suggest you need chain slack when laden.
grr666
PostPosted: 09:10 - 10 Aug 2019    Post subject: Reply with quote
It's an MT09 in different frock. My chains taut on mine, gets a bit noisy if there's any noticeable play in it.
No extended swingarm or fork travel at all, it's a road bike dressed as a scrambler, like that Ducati thing.
jaffa90
PostPosted: 09:52 - 10 Aug 2019    Post subject: Reply with quote
Bike drive chains should not be taut, see them wagging about on MOTO GP or W,S.B.
grr666
PostPosted: 09:58 - 10 Aug 2019    Post subject: Reply with quote
When I say taut I mean about an inch of play, about right for road use. My point was that it doesn't need to be nearly
as baggy as a dirt bikes chain, it may look like a scrambler. It isn't. Same frame and suspension as mine. I should add
my first MT09 foray off road didn't end well so I have practical experience as to their unsuitability. Laughing
Grubscrew
PostPosted: 10:07 - 10 Aug 2019    Post subject: Reply with quote
I end to get a person to sit on the bike and get the slack correct in a laden situation, which I think is way to go.
The Africa twin original version required this method.
FJR1300/CBR1000F
The last post was made 6 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 59.66 Kb
