Xbox storage external issue
King29
PostPosted: 18:09 - 11 Aug 2019    Post subject: Xbox storage external issue Reply with quote
I have a 500GB external hard drive for my Xbox one. I bought a 1TB external hard drive. I have an Ineo copy machine hot swap drive device and copied the contents in auto mode from one drive to the other. Plugging the new drive in and Xbox sees it as a 500GB and not a 1TB.
Why? and how fix?
RhynoCZ
PostPosted: 20:30 - 11 Aug 2019    Post subject: Reply with quote
Did you copy the files or cloned the drive? If you cloned it, it would explain a lot.
King29
PostPosted: 20:32 - 11 Aug 2019    Post subject: Reply with quote
My PC can't read the files I just took the USB lead out of the Ineo and inserted the 2 drives, 500GB and 1TB and hit clone. It cloned it, I assumed it would dump all the data from a-b but I'd have more storage left on b?
Easy-X
PostPosted: 00:43 - 12 Aug 2019    Post subject: Reply with quote
It cloned it, it cloned it perfectly. Even down to the 500GB partition size. What did you expect? You expected it to mirror and re-partition the drive?! Rolling Eyes
Google is your friend Smile Loads of people have done the same thing and had the same problem. In essence you either need to clone again but with smarter software or expand the partition (gparted etc.) to fill the available space.
PostPosted: 08:43 - 12 Aug 2019    Post subject: Reply with quote
Why have you even tried to do anything other than plug in to the Xbox and press 'move'
Assuming you've replaced external for external, just plug both in, choose to move games to other storage. Hopefully you've purchased SSD, otherwise you've done yourself a disservice.
King29
PostPosted: 10:32 - 12 Aug 2019    Post subject: Reply with quote
I can't plug both in. I've only 1 Caddy. It's a 2.5 1TB, drive only. When I plug the Ineo into the Xbox it does not recognise it. I need another caddy I suppose.
Thanks all anyway. Get another Caddy and do what Paddy says and transfer files.
PostPosted: 19:38 - 12 Aug 2019    Post subject: Reply with quote
I wouldn't bother if its non SSD man... honestly.
Also, no caddy needed, just grab a USB3 to SATA3 cable.
The last post was made 7 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 50.72 Kb
