| kramdra |
 kramdra World Chat Champion
| Grubscrew |
 Grubscrew Scooby Slapper
| Bhud |
 Bhud World Chat Champion
 Posted: 20:33 - 05 Aug 2019 Post subject: |
With a blocked return hole in the master cylinder, both sides would be affected, so I doubt it's that.
From what I understand, it's the lip on the piston seal that very slightly flicks back the piston when you release the brake. This won't work properly if there's an obstruction (e.g. some dirt around the piston or seal, or a scored/nicked piston). Another cause of this problem may be hydraulic brake fluid that's no good because of molecular changes (e.g. it's old or got too hot once). There is also the possibility that you may have air in the right brake or in the brake line from the right brake up to the junction. Finally, old rubber brake hoses can do this, especially after they've been clamped with mini molegrips (developing cavities along the inside which misbehave irregularly).
It was more than one of these things on my project bike. It started as mild binding (still passed the MOT) and very quickly developed into an unusable and dangerous condition that threatened the disc with warping. Never pinned down exactly which faults it had, but by the time it was fixed, I had replaced all the brake lines, the master cylinder, the brake seals and flushed the brake fluid. |
| MCN |
 MCN Super Spammer
 Posted: 11:26 - 06 Aug 2019 Post subject: |
Look at most likely causes.
Shite build up in the pad slide areas. Old brake dust can bake to resemble metal.
Brake cleaner alone won't shift it and it needs a file or an old flat screwdriver to remove it.
Then a slight smear of an anti-seize copperslip molybdenum disulphate (or whatever it's real name is) paste. Sparingly as it can creep onto pads.
Wrong brake pads or incompatible pads. Metal backing plates do not have any clearance to slide freely.
If you've changed pad compound then it's prudent and recommended to remove the old pad residue from the surfaces of the discs too. Not a joyous or satisfying task but it will help your new pads to perform better.
Needs a few sheets of wet or dry.
I jacked the wheels up and drove the wheel around using my drilling machine and a buffer pad.
Don't go mental with the rpms your guaranteed to catch your fingers then.
You should bed in the new pads too. Needs some moderate braking to warm up the pads and the discs.
Then hammer the brakes a few times to melt the material onto the discs.
If you can't resolve the binding issue then postpone the bed in. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| kramdra |
| RhynoCZ |
 RhynoCZ Super Spammer
| Tankie |
 Tankie Crazy Courier
| MCN |
 MCN Super Spammer
| kramdra |
| kramdra |
| kramdra |
| Tankie |
| Bhud |
| kramdra |
| weasley |
 weasley World Chat Champion
| kramdra |
| Tankie |
| sickpup |
 sickpup Old Timer
| Bhud |
| kramdra |
The last post was made 6 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
