Aftermarket shocks and automatic compression/rebound balance
hirmalde
PostPosted: 20:47 - 14 Aug 2019    Post subject: Aftermarket shocks and automatic compression/rebound balance Reply with quote
Hello all, I have a 2016 cb650f on which I'm looking to upgrade the stock rear shock with something softer sprung and ideally adjustable for rebound at the very minimum.
The stock forks are pretty soft and undersprung as they usually are on these cheaper bikes although they seem to be about right for my weight in terms of static and rider sag and feel but the rear shock jars my spine over every single bump in the road surface! Preload is wound all the way out but still. I'm fairly light at 71kg without gear so I'm pretty sure it's the shock and nothing else. I've even reduced tyre pressures down to about 30psi front and rear from 36,42 and no difference. Bike primarily used for commuting but I hit the twisties every week or so too.
For the cb650f there aren't many options but I've looked around and narrowed it down to either YSS or Hagon which both offer a full replacement shock and will fit a softer rate spring for me. YSS with rebound adjustability and Hagon with automatic compression/rebound balance (which I have no clue how it works).
Would anyone be able to share some insight into the two brands and also clarify what automatic compression/rebound balance is and if it works well or not? (I emailed Hagon but no reply as of yet).
Thanks
wr6133
PostPosted: 21:27 - 14 Aug 2019    Post subject: Reply with quote
I have YSS on my ZZR and had one on the ZZR before that too. I have no complaints. You can tell they are built to a price from feel and finish but ridewise it's fine (and in the case of the ZZR vastly better than stock).
hirmalde
PostPosted: 21:40 - 14 Aug 2019    Post subject: Reply with quote
ZZR 1100? Was stock too wallowy/soft?
By fit and finish you mean stuff like the paint flaking off possibly on the spring, etc?
wr6133
PostPosted: 22:04 - 14 Aug 2019    Post subject: Reply with quote
ZZR600 the stock shock is crap, it's like a 1980's pogo stick... not a new 1980's pogo stick, an actual one, well used, left in a garden and recently rediscovered when cutting back a hedge.
By finish I mean you can feel slightly rough edges and the paint/powdercoat seems a little thinner than much more expensive stuff. I'd heartily recommend them for the price, beyond nitpicking at minor details I can't really fault mine.
hirmalde
PostPosted: 22:34 - 14 Aug 2019    Post subject: Reply with quote
Hehe fair analogy, it must've had little or no damping in that case. Great all round bikes though aren't they?
Both shocks are £300 so reasonable I guess compared to Ohlins or or the like. Guess it'll come down to warranties and after sales support (or lack there of).
redeem ouzzer
PostPosted: 22:43 - 14 Aug 2019    Post subject: Reply with quote
Have a YSS on my GSXR1100, works fine in what is a fairly demanding application. I’d use something better if I rode it on track but as a road shock I can’t fault it.
Be a REAL MAN!
PostPosted: 07:32 - 15 Aug 2019    Post subject: Reply with quote
I have a nitron on my VFR. £100 more than a YSS but probably worth it. Once the compression damping was set up it's like a magic carpet.
Robby
Dirty Old Man
PostPosted: 20:08 - 17 Aug 2019    Post subject: Reply with quote
Can you just change the spring? I recently put a pair of softer springs on the back of my Guzzi, a pair of them only cost 50 quid.
Doesn't change the fact that shocks are cheap crap, but it does mean my spine doesn't get jarred every time I hit a bump.
PostPosted: 20:36 - 17 Aug 2019    Post subject: Reply with quote
Also Wilbers.
https://www.wilbers-shop.de/en/Motorcycle/Honda/CB-650-F-RC75/?cur=1&year=2016
1198
PostPosted: 20:45 - 17 Aug 2019    Post subject: Reply with quote
The best few tenners I ever spent on suspension was getting my bike set up professionally. I only paid for the static set up but if you’ve got adjustments possible at both ends I’d say it’s definitely worth it.
The last post was made 6 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 64.94 Kb
