| Nels19 |
 Nels19 L Plate Warrior
| jaffa90 |
 jaffa90 World Chat Champion
| Riejufixing |
 Posted: 01:32 - 15 Aug 2019 Post subject: Re: Lexmoto Isca 125 HELP!!! |
| Nels19 wrote: | I never touched the inlet or exhaust valve until 3000 miles ... I cannot even get the bike to start. It just doesn’t even sound anywhere close to starting up if you know what I mean. I have again adjusted the inlet and exhaust valve and it still will not start.
Would the inlet and/or exhaust valve being to loose or too tight cause the bike not to start up or is this a completely different problem |
It might cause a problem, but if it *is* the problem, the valve(s) would have to bee in really, really poor condition for it not to start, or really, really badly out of adjustment. I would be inclined to do a rudimentary compression test on it. Get the sparking plug out, stick the bike in say second gear, jam your finger on the plug hole, andtry to push the bike gently forwards (maybe get a helper to steady it). If you can feel little pressure there's a problem of some sort. If it has plenty of pressure and pushes your digit off the plug hole it's less likely to be a problem.
Hm. You have checked the spark/tried a different sparking-plug, haven't you? An old one that you know works, or a new one? Nice zappy zap blue spark to be seen? |
| Nels19 |
| Nels19 |
| Sister Sledge |
| Teflon-Mike |
 Posted: 10:06 - 15 Aug 2019 Post subject: |
Motorbikes need maintaining... if you dont take it to a dealer to service, who gonna do it? You? Do you know what you are doing? If you had toothe ache, wold you a) go to a dentists, b) try giving yourself a filling DIY with a dremmel and a mirror an a you tube video? This is sort of the analkogy to what yopu are trying to do here!
NOW we are pizing in the dark, trying to diagnose your problems,n not just by renote control, and voodo but shear clairvoyance, given the terse lkack of description of what the peoblem even is!!
Tappets.... yeah; it will need these adjusted aprox every 15oo miles, 25oo KM or so. Is the clerances are wrong lots of things dont work well and poor starting is but one of them! What else neds doing you dont know about or know how top do?
Battery related? GOOD ODDS. little 125's are not nery powerful, so they dont tend to have particularly generouse generators to steal any of the power they may msker; add oners who often get scared of hearing the little motors rev much and so short shift up the gears and make the motprs labour at lower revs NEVER making even the electric generator might... AND using the lights 24/7 cos DTRL meanms 'safety', doing short hops never letting motor get properly warm, or giving struggling genny enough time to top up the battery THEN hammering the battery and sucking out big chunk of any electric genny may have shoved oin it, over using the e-start for longer than probably needed... batterioes go flat... and this is EFI engine with an electrif fuel pump that has to pump up fiel pressure to make squirterds work, an electric brain that needs electric to make squirter work, if the battery is low and the terminl volts drop, s they do when the starter button pressed, the pump and ECU can stop working, and the vike wont start, especilly as starter will probably sp[in motor over too slow to 'catch'......
Start by putting the battery on charge... a good and proppa charge like over night on a 4a bench charger, not hal;f an hour on an omptimate or anything!
THEN, forget the thing has gears.. go thrash it a bit, if it starts good.... and take the hint that that was the problem all along.... THEN either learn mechanics PDQ or read the service schedule in the oiwners book, find a half decent paid mechanic.. note paid mechanic NOT mate down the road who's had a couple of peds before.... and get the thing serviced at the propper intervals by some-one who knows what they is up to!
If charging the battery and thrashing it a bit dont help... well... we are pizzing in the dark; we dont know what you have/haven't done or whats not right... take the thing to that paid for mechanic who shouild and should be able to tell whats actually wrong with it with bike actually in hands reach! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Nobby the Bastard |
| linuxyeti |
 linuxyeti World Chat Champion
| Evil Hans |
 Evil Hans World Chat Champion
The last post was made 7 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
