| Codey90 |
 Codey90 Derestricted Danger
 Posted: 22:23 - 17 Aug 2019 Post subject: Rear Master Cylinder Screws |
Hi All,
Having an issue with two screws on my rear Master brake cylinder. They are barely accessible due to a part of the frame running above the top of it. I've tried an offset screwdriver but they don't fit very well even after trying four sizes.
The screws, as you can also see are rusted and very difficult to turn using a bit in a wrench without potentially stripping them. I've left them to soak in WD40 overnight and am tempted to try an impact screwdriver but the only way would be to use the driver at an angle due to the frame obstructing a perpendicular fit. Any other ideas?
https://imgur.com/a/GBjgqX7 |
| Riejufixing |
| Codey90 |
| NJD |
 NJD World Chat Champion
| Codey90 |
| NJD |
| Kawasaki Jimbo |
| Riejufixing |
| Codey90 |
 Posted: 00:55 - 18 Aug 2019 Post subject: |
They are JIS screws. You can tell by the little "dent" to one side of the cross. If you don't have a specific JIS screwdriver, you wont get them out without stripping the heads regardless of how well you can get at them. Phillips or posidrive will not fit properly. I've never seen a right angle JIS driver.
Sometimes filing the tip down a few mm on a phillips scredriver will take it closer to fitting a JIS. If the bike came with a toolkit (or you have a toolkit from a Japanese bike), the cheap looking screwdriver with the removable plastic handle is a JIS. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Codey90 |
The last post was made 7 years, 49 days ago. Instead of replying here, would creating a new thread be more useful? |
