Aprilia RS125 Damaged Crankshaft
Danonymoose
PostPosted: 09:05 - 18 Aug 2019    Post subject: Aprilia RS125 Damaged Crankshaft Reply with quote
Hi.
I recently posted with some issues with my 122 engined '05 RS125. I thought the issues were to do with the carb/fueling. Boy, was I wrong.
After getting a break in the bad weather recently, I've been able to start fault finding on the bike again. I figured that the bike was, indeed, getting fuel, and it seemed to be an ignition/spark problem.
The spark was okay, but not the best I've seen. I started testing the electrical components one by one. Ignition switch? Fine. Coil/lead/cap? Fine. CDI/ICU? Fine. I finally got down to the pickup. I took it off, cleaned it up, tested it, and it was fine. However when I took the pickup off, I noticed the air gap was pretty large. So upon refitting it, I got my feeler guage out and made the sure it was gapped properly. Lo and behold, a decent spark! Or, at least, it was much better than before, if still not perfect.
Anyway, I noticed that the stator cover was pretty dirty. I decided to remove it to give it a good clean. Welll... This is when I noticed that something wasn't right. After removing the cover, I decided to also remove the stator itself. This is when my world came crumbling down around me.
The woodruff key was lying on it's side in what was once the slot that it fits in on the end of the shaft. It looks as though it's somehow wriggled loose, and has eroded away at its home in the shaft, leaving a half moon shaped pit where the slot originally was.
Does anyone have any experience with issues like this? I've been searching online, and while there are plenty of places that offer crank rebuilding, this only really seems to cover seals and bearings etc. and not work on the actual crankshaft itself.
I can throw some pictures up later to show exactly what I mean, if needed.
redeem ouzzer
PostPosted: 10:13 - 18 Aug 2019    Post subject: Reply with quote
You’ll be wanting it rebuilt with a new crank web then....
Be a REAL MAN!
Riejufixing
PostPosted: 10:41 - 18 Aug 2019    Post subject: Re: Aprilia RS125 Damaged Crankshaft Reply with quote
Telephone a couple of them and tell them that the key seat in the crankshaft's damaged, and talk it over. It's possible that some firm has odds and ends lying about which could be used (or could re-cut the seat in a different position, but that might be more expensive). Also, look arount for used components; there's a "crank with siezed bearing" on eBay now, or a "bottom end" which has a crank in it for £110 "or best offer" (EDIT this also has the generator rotor which you will probably need & stator, who knows the thing could actually be usable and might have parts you could resell). Dunno whether a supplier could get you a new shaft to be pressed in (?).
Nobby the Bastard
Harley Gaydar
PostPosted: 11:00 - 18 Aug 2019    Post subject: Reply with quote
Are you sure the slot is damaged? Slots for woodruff keys are meant to be a half moon shape.
In addition, having sheared a woodruff key in the past, they are a lot weaker than the crank. I seriously doubt that the woodruff key had damaged it.
Triumph Sprint ST 1050
Riejufixing
PostPosted: 11:27 - 18 Aug 2019    Post subject: Re: Aprilia RS125 Damaged Crankshaft Reply with quote
G'won then... pictures are always good.
PostPosted: 12:28 - 18 Aug 2019    Post subject: Reply with quote
Put up some pics. Odds-on that the broken key has chewed up the taper a bit. How fixable it is depends on the amount of damage. Quite often all that is required is a small clean-up and a new woodruff key.
PostPosted: 12:54 - 18 Aug 2019    Post subject: Reply with quote
If you're lucky, you'll be able to lap the flywheel back against the taper and fit a new key.
As above, Key steel is usually a LOT softer than the steel of the crank. Woodroffe keys are usually half-moon shaped anyway.
Check for play on the end of the crank (grab the end and wiggle it up and down and in and out, it shouldn't move). I've seen flywheels spin-up or altered pickup clearance (on older bikes, broken points baseplates) because of play in the main bearings.
Riejufixing
PostPosted: 13:16 - 18 Aug 2019    Post subject: Reply with quote
Needs pics, as he said. I can't reconcile "The woodruff key was lying on it's side in what was once the slot that it fits in on the end of the shaft. It looks as though it's somehow wriggled loose, and has eroded away at its home in the shaft, leaving a half moon shaped pit where the slot originally was" with an undamaged key seat (and possibly a knackered key slot in the rotor).
PIC, Danonymoose, pics! Smile
PostPosted: 13:22 - 18 Aug 2019    Post subject: Reply with quote
I've seen moon-crater-like damage from a busted key. Much depends on the extent of the damage.
Danonymoose
PostPosted: 13:52 - 18 Aug 2019    Post subject: Reply with quote
[/url]https://imgur.com/gallery/SfLTGdl
Danonymoose
PostPosted: 13:57 - 18 Aug 2019    Post subject: Reply with quote
There's no play at all on the crank
Riejufixing
PostPosted: 14:07 - 18 Aug 2019    Post subject: Reply with quote
Danonymoose wrote:
Mmm, lovely. Eurgh!
Go back to post "Posted: 11:41 - 18 Aug 2019"!
Edit: What damage to the generator rotor?
Danonymoose
PostPosted: 14:16 - 18 Aug 2019    Post subject: Reply with quote
Riejufixing wrote:
Danonymoose wrote:
Mmm, lovely. Eurgh!
Sorry, I thought I'd already replied to that comment.
I'll be making some phone calls tomorrow to see who can do what.
I don't know what damage has been done to the rotor. In all honesty, I don't know what I'm looking for, damage wise.
Nobby the Bastard
Harley Gaydar
You need a new crank. That's not fixable. You may be able to get away with finding a crank withe the other end fucked to get the nessecary parts cheap but you are still looking at a crank rebuild.
I'd be looking for a decent rebuilt crank as the cheapest solution.
Danonymoose
PostPosted: 14:19 - 18 Aug 2019    Post subject: Reply with quote
That's more or less what I imagined was going to be the case. I'm looking for cranks with a knackered opposite end that I can salvage that half from.
Riejufixing
PostPosted: 14:27 - 18 Aug 2019    Post subject: Reply with quote
Danonymoose wrote:
Riejufixing wrote:
Mmm, lovely. Eurgh!
I meant that the advice there is what you need to do.
Examine the slot in the rotor, where it should slide over the woodruff key, and see if it's knackered or whether it's clean and undamaged. I would bet that it is knackered, and I would not put a knackered rotor back on a repaired/replaced crankshaft.
Riejufixing
PostPosted: 14:38 - 18 Aug 2019    Post subject: Reply with quote
https://www.ebay.co.uk/itm/APRILIA-RS125-2T-Crankshaft-With-Seized-Bearing/254333148747?hash=item3b376fde4b:g:k3oAAOSwRn5dDjcS (will need recon)
https://www.ebay.co.uk/itm/Aprilia-RS125-Rotax-122-Flywheel-Fly-Wheel-Rotor-Magneto-CDI-RS-125/320827802029?hash=item4ab2d3c1ad:g:2q4AAOxyJ8ZRgeTl
OR:
https://www.ebay.co.uk/itm/apilia-rs125-rs122-122cc-1996-2010-fly-wheel-rotor-AP0295677/273407251109?fits=UKM_Make%3AAprilia&epid=848466574&hash=item3fa85792a5:g:A3IAAOSwhDBZ6Jas
OR:
https://www.ebay.co.uk/itm/APRILIA-RS125-GENERATOR-ROTOR-WINDINGS-ROTAX-122/331722910475?hash=item4d3c39eb0b:g:vI0AAOSwfZ1WXva4
INSTEAD PERHAPS:
https://www.ebay.co.uk/itm/APRILIA-RS125-rotax-122-ENGINE-botttom-end/153555583183?hash=item23c0a040cf:g:EloAAOSw0cVdINiC
"The unknown alternative".
PostPosted: 14:46 - 18 Aug 2019    Post subject: Reply with quote
If you want to box that up and send it to me I will "try" to weld it up and make a new keyslot, then straighten the taper well enough so that it will run the rotor true. I expect that the rotor is also fairly well battered.
Actually if you send me the crank and the rotor I could try cutting a new keyway in both in a different location. You got nothing to lose.
Riejufixing
PostPosted: 15:03 - 18 Aug 2019    Post subject: Reply with quote
That's a *lovely* offer!
PostPosted: 15:08 - 18 Aug 2019    Post subject: Reply with quote
That's got to be the best/only way to save that crank. Thumbs Up
Danonymoose
PostPosted: 15:30 - 18 Aug 2019    Post subject: Reply with quote
That's an awesome offer, thanks. I'll send you a PM!
redeem ouzzer
PostPosted: 16:25 - 18 Aug 2019    Post subject: Reply with quote
You could get away without the key provided the taper laps in ok but you’d need to use a dial gauge to set the timing when fitting the rotor (proper race ignitions don’t use a key). The key doesn’t actually do any driving, it’s just to make assembly easier.
Be a REAL MAN!
Easy-X
PostPosted: 21:11 - 18 Aug 2019    Post subject: Reply with quote
I don't suppose my usual "a dab of JB Weld will sort that right out" will help...
...I'll get my coat Wink
The last post was made 7 years, 89 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 126.26 Kb
