Electrical problem on Kawasaki ER 5
running on empty
PostPosted: 12:28 - 19 Aug 2019    Post subject: Electrical problem on Kawasaki ER 5 Reply with quote
I fitted new plugs on my bike. It was going ok before I changed them. Then it wouldn't start. I found that the left plug wasn't sparking. I swopped the coil and lead from the right side over to the left and found it wasn't sparking. The voltage is the same on the left coil as the right. Then I swapped the coil that was originally on the left over to the right and it didn't spark. I have established that the coil on the left is faulty and that both plug leads are ok. Obviously there is an electrical problem on the left side. I wonder what it could be. The rectifier went a few weeks back.That may have burned out the coil on the left and done damage to some electrical part through overcharging.
Tdibs
PostPosted: 14:39 - 19 Aug 2019    Post subject: Reply with quote
Check all the connections to and around the rectifier for signs of melting/damage.
jaffa90
PostPosted: 15:04 - 19 Aug 2019    Post subject: Reply with quote
"""""""""""I fitted new plugs on my bike. It was going ok before I changed them. Then it wouldn't start. I found that the left plug wasn't sparking"""""""""""""""""
From what you say have you checked the spark plug?
hawkeyefxr
PostPosted: 15:01 - 20 Aug 2019    Post subject: no spark at new plugs Reply with quote
Have you tried putting the old plugs back in? I have heard that spark plugs are being faked now, these barstards are faking everything these days !!.
This is not a joke, it was on the beeb.
running on empty
PostPosted: 09:30 - 21 Aug 2019    Post subject: Reply with quote
[quote="jaffa90"]"""""""""""I fitted new plugs on my bike. It was going ok before I changed them. Then it wouldn't start. I found that the left plug wasn't sparking"""""""""""""""""
From what you say have you checked the spark plug?[/quote]
I checked the spark plug by putting it into the spark plug cap then touching it off the frame and turning the engine.
running on empty
PostPosted: 09:35 - 21 Aug 2019    Post subject: Re: no spark at new plugs Reply with quote
[quote="hawkeyefxr"]Have you tried putting the old plugs back in? I have heard that spark plugs are being faked now, these barstards are faking everything these days !!.
This is not a joke, it was on the beeb.[/quote]
I used the old plug to check the spark by putting it into the spark plug cap, touching it off the frame and turning the engine. So its not the new plugs that are faulty.
jaffa90
PostPosted: 11:28 - 21 Aug 2019    Post subject: Re: no spark at new plugs Reply with quote
Are you now saying the old spark plug did not spark???????????
running on empty
PostPosted: 12:07 - 21 Aug 2019    Post subject: Re: no spark at new plugs Reply with quote
Are you now saying the old spark plug did not spark???????????[/quote]
No it is sparking on the right lead but not on the left one.
The last post was made 7 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 54.57 Kb
