| Freddyfruitba... |
 Posted: 14:38 - 20 Aug 2019 Post subject: Glass fibre pannier repair now failing |
Earlier this year I repaired a cracked pannier by reinforcing the damage inside with glassfibre, then body filler/rattlecan outside - was quite pleased with the result. However, a few months later the crack is now beginning to show through on the outside,and looking inside I can see that the glassfibre is becoming unbonded from the pannier surface - in the photo below, the whole area was translucent where the glassfibre was stuck fast to the substrate, but as you can see there's now a large (and presumably still increasing) opaque area where the bond between the plastic and glassfibre surfaces is broken.
Do we think this is likely to be caused by incompatibility of the resin with the plastic of the pannier? Or small movements in the pannier body causing the bond to break? Just wondering whether it's worth chucking in a couple morre layers of glassfibre on top... in all honesty I'm not going to remove all the old stuff whatever, as that would also mean repeating all the work, including painting, on the outside
https://i.imgur.com/Hqvm7pC.jpg?1 ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
| colink98 |
 colink98 Could Be A Chat Bot
| A100man |
 A100man World Chat Champion
 Posted: 15:57 - 20 Aug 2019 Post subject: |
I don't think you used enough layers of matting or 'keyed' the base. Use a sharp knife (mind your fingers !) to cut out teh 'unbonded' bits and rough up the surface - enlarging the repair area as you go. then 3-4 layers of well wetted matting.
Well that's what I'd do. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Riejufixing |
| Grubscrew |
 Grubscrew Scooby Slapper
| A100man |
 Posted: 22:18 - 20 Aug 2019 Post subject: |
| A100man wrote: | I don't think you used enough layers of matting or 'keyed' the base. Use a sharp knife (mind your fingers !) to cut out teh 'unbonded' bits and rough up the surface - enlarging the repair area as you go. then 3-4 layers of well wetted matting.
Well that's what I'd do. |
Yeah, well that, or those microballoon thingies obviously  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Freddyfruitba... |
The last post was made 7 years, 86 days ago. Instead of replying here, would creating a new thread be more useful? |
