TZR125 carb, more fuel outside than in.
Git
PostPosted: 16:39 - 27 Mar 2005    Post subject: TZR125 carb, more fuel outside than in. Reply with quote
Hi, I have a bit of a problem.
I have this carb in front of me and it's leaking fuel out the overflow pipes.
I have checked the float heights, they ok.
Floats look fine, don't think they are split.
Needle valve and seat look good.
But,
the needle is shot and I would not be surprised if it has taken the needle jet with it, it will be getting these as soon as I can order them next week but could they cause the problem of the carb filling up with too much fuel when the engine is off? I always thought the needle valve controlled this?
Any thoughts appreciated Smile Crying or Very sad
BlueNinja
PostPosted: 16:56 - 27 Mar 2005    Post subject: Reply with quote
Hey.
Could be your fuel switch diaphragm nackered, and its gravity feeding heaps of fuel into the carb?
Other wise rebuild the carb with new gaskets, and the parts you mentioned that were damaged. Then put the carb back, and run it on Redex carb cleaner. Thumbs Up
Big Kawasaki ZXR 400 project here:
https://www.theundertaking.com/index.php?showtopic=483
Git
PostPosted: 18:32 - 27 Mar 2005    Post subject: Reply with quote
Well the taps brand new so that should phase that out.
The only gaskets I can see are on the float bowl and on the needle valve holder, may just buy them aswell as they do have age against them but look fine..
Can only try an see.
cagiva gezzer
PostPosted: 18:38 - 27 Mar 2005    Post subject: Reply with quote
Which overflow pipes?
Git
PostPosted: 18:41 - 27 Mar 2005    Post subject: Reply with quote
The one on the float bowl and one further up, a tiny one, about an inch from top of the bowl joint.
Now with picture..
PostPosted: 19:05 - 27 Mar 2005    Post subject: Reply with quote
Sounds like it is the needle valve leaking or the floats holed. Take the floats off and check them (are the clear, black, solid, etc?, some are foam filled so if they leak they will just get very heavy). Also check that it pivots smoothly.
The needle jet will not have any effect on this.
Git
PostPosted: 20:05 - 27 Mar 2005    Post subject: Reply with quote
Thank's greatly for that, certainly cleared allot up.
The float pivots fine, all smooth there. it's a black plastic float, not sure if it's foam inside or not, sounds pretty solid.
I just gave the float a dunking in a bowl of water, it's still floating and doesn't appear to be leaking air when under..,going by the state the needle/jet was in, 2 years of water/mayo, crust and rust, getting expensive now, better tell him my fears, I need more money for another bit Shocked
Needle valve or float/both.. do yamaha do a rebuild kit...
/looks for carb dealer
PostPosted: 20:59 - 27 Mar 2005    Post subject: Reply with quote
Sounds like the needle valve then. They should be fairly cheap from Yamaha.
simon1221
PostPosted: 19:22 - 28 Mar 2005    Post subject: Reply with quote
Petrol used to run out of mine, but never on the higher breather pipe, just the black one underneath. Confused
Git
PostPosted: 11:19 - 29 Mar 2005    Post subject: Reply with quote
The shopping list so far.
Needle set, nozzle, needle valve, needle valve seat.
guess how much Shocked Shocked £150 Shocked Shocked
/falls over
simon1221
PostPosted: 14:19 - 29 Mar 2005    Post subject: Reply with quote
Thats a bit bollocks, could you not just order the parts from somewhere who does mikuni carbs and give them the model number?
Git
PostPosted: 15:19 - 29 Mar 2005    Post subject: Reply with quote
Very well said Laughing
Just trying some carb specialist guy now, just given him details and the like and need to call back in a while to see what he's found out but he mentioned that I should get a few pennys change from 20quid, we shall see Confused
The last post was made 21 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 71.76 Kb
