| FelixBisto |
 FelixBisto L Plate Warrior
| bikenut |
 bikenut World Chat Champion
 Posted: 13:47 - 22 Aug 2019 Post subject: vibs |
https://www.fowlersparts.co.uk/main/img/assemblies/large/694aac16f15a5262d34a7e327edd29fd.png?6
cmsnl dont list this.......
so what thrust bearing exactly? part number 5?
clutch basket part number 1 and its bush is expensive and has shock absorbing springs by the look of things.
notice the clutch is nutted onto the input shaft.
if you are convinced its a clutch problem then remove cover and inspect......
notice......https://www.fowlersparts.co.uk/main/img/assemblies/large/706418cabadae9d2703890362f5e9644.png?6 34....is the engine loose??
interesting....https://www.fowlersparts.co.uk/main/img/assemblies/large/e97b33a77c462a1fbefc219e4e5beadd.png?6 crank thrust shells part 6 and 7, crank end float....
no balance shaft/weight system in this engine.... ____________________ nuts about bikes |
| FelixBisto |
| bikenut |
| FelixBisto |
| bikenut |
 Posted: 10:36 - 23 Aug 2019 Post subject: clucth |
Sadly all the words you said somewhat went over my head.
oh dear, look at the pictures and try to understand whats what and how it works, not rocket science believe me.
How do you intend to stop the clutch nut from turning the shaft when you undo it??
The bike has the means so have a little think about that.
looking at that diagram again, do you have to undo the nut??
to replace the clutch plates??? ____________________ nuts about bikes |
| FelixBisto |
The last post was made 7 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
