| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| steve the grease |
| Nobby the Bastard |
| steve the grease |
| Islander |
 Islander World Chat Champion
| 1198 |
 1198 World Chat Champion
| Riejufixing |
 Posted: 13:36 - 26 Aug 2019 Post subject: |
| Irezumi aka Reuben wrote: | Thanks for the advice, I'll stick to the jug and tube method then. |
Oh, I don't know; they are often useful. I've got an old Gunson's Easibleed kit which is OK for cars, but for bikes the brake resevoir shape/position can be a problem. You can make "lids" with offcuts of metal/plastic and an old bicycle valve (works well), or you can re-jig the connections to reverse-bleed from the caliper end (works well), or I don't see why an ordinary vacuum cleaner shouldn't be used to pull the fluid out from the caliper end (grease up the bleed nipple to stop leaks, connect to a resevoir bottle with tube, connect the resevoir bottle to the vacuum cleaner hose with a bung, leave the vacuum reducer on the vacuum cleaner hose open to reduce the suck/preserve the vacuum motor. Mind you, if you've got a wifely object, she might take umbridge if you let the fluid go up the vacuum cleaner hose, so take care. |
| Nobby the Bastard |
| Ste |
 Ste Not Work Safe
 Posted: 13:43 - 26 Aug 2019 Post subject: |
Reverse bleed for the win.  |
| Tdibs |
 Tdibs Traffic Copper
The last post was made 6 years, 305 days ago. Instead of replying here, would creating a new thread be more useful? |
