Mash 50 Roadstar cutting out...
Spike13
PostPosted: 16:36 - 27 Aug 2019    Post subject: Mash 50 Roadstar cutting out... Reply with quote
Hi my Mash 50 has cut out in traffic again when i rev hard.
Does anyone know where the fuel adjust screw is on the Carb, Ive found the idle already, thanks
- Spike
Spike
PostPosted: 17:24 - 27 Aug 2019    Post subject: Reply with quote
If it is cutting out at high revs, it can't be fixed by adjusting a screw on the carb.
The idle screw adjusts the idle speed. The fuel air (pilot) screw fine-tunes the fuel delivery between 0 and 1/8 throttle opening.
The only setting on the carb that will affect fuelling with a wide open throttle is the main jet diameter.
Check the fuel tank breather vent and the fuel filter. Cutting out at high revs is more likely to be a fuel starvation problem.
Spike13
PostPosted: 10:21 - 28 Aug 2019    Post subject: Reply with quote
Smile
Cheers mate, tried revving hard today in neutral, fuel cap off, same result!
Good advice, will just go local garage!!!!!
Cheers mate
Spike
The last post was made 6 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 35.12 Kb
