First track day booking
myvision
PostPosted: 12:17 - 28 Aug 2019    Post subject: First track day booking Reply with quote
I'm looking at booking Cadwell Park on the 25th October now i've got a set of full leathers and all the other safety gear. (Only had flipup helmets before as well).
I'm under no illusion that i can book any higher than the novice group so i'm after advice on a couple of things as below,
1, I'll be going on the bike so can only take what i need what will i need? A few tools, change of pants?
2, Can i leave the backbox rack on?
3, Is it worth strapping some petrol cans on or just buy it at the track?
4, Do i need to remove mirrors and tape up headlights?
5, How fast are the novice groups?
6, Is it worth paying the extra £25 for 20 minutes following a professional?
Any advice appreciated.
Booking the day of work now so hopefully booking the day ASAP.
Cool
VFR800FI, YZF600R Thundercat and FZS 1000
PostPosted: 12:26 - 28 Aug 2019    Post subject: Reply with quote
Food, drink, tools if you think you'll need them, but I probably wouldn't bother unless I was trailering or using a van.
Don't see why not.
You'll certainly need more than one tank of fuel, which you can buy at the circuit but it's VERY expensive. There used to be a petrol station down the road in Scamblesby but that has now shut down sadly.
You're supposed to, but you can probably just fold in mirrors. I'd also tape up my number plate too though.
Depends. The pace has widened over the years, with people who should be in inters booking novice, and people who have barely passed their bike tests also booking in novice. You'll be fine though, the pace is not important, what is important is that people pass you with respect.
Maybe? You should have booked with No Limits who give free instruction. Personally I'd do a couple of sessions without first and then try an instructor. The key thing about Cadwell is learning the lines (same with most circuits) then learning which gear to take each corner. Once you have that you should get faster. Hopefully they'll have cones out to guide the turn in points and the apexes.
Warning: It's addictive.
redeem ouzzer
PostPosted: 15:42 - 28 Aug 2019    Post subject: Reply with quote
If you are with MSV i would deffo take an instructed session, possibly once you've done a few sessions so you have some ideas what you want to work on.
I also suggest you take a footpump and tyre gauge as well.
Be a REAL MAN!
myvision
PostPosted: 16:50 - 28 Aug 2019    Post subject: Reply with quote
Thanks lads I've booked it if i can't have the time off i'll pull a sickie fuck em.
Whosthedaddy
PostPosted: 19:07 - 28 Aug 2019    Post subject: Reply with quote
It is great, I did one 10 years ago and again this summer. I would like to try and do some more if possible*
I rode the bike to the track, made sure I had a full tank and apart from folding in the mirrors, taping the speedo and adjusting the tyre pressures a little, that's it?
I was pretty much one of the slowest riders in my novice group by choice more than anything? I was more trying to concentrate on the lines and gears as it is sensory overload when on track.
Relax and enjoy yourself.
It is addictive and very very safe
* I've since booked a i2i kneedown session and a Premier session with the Ron Haslem Race school
Pigeon
PostPosted: 20:47 - 28 Aug 2019    Post subject: Reply with quote
Not to be too much doom and gloom, it's not "very very safe", especially the Novice sessions.
Novice group contains a really wide spectrum of abilities, partly because people don't know themselves, but you also get the guys who like buzzing noobs.
Also, once a couple of sessions are under their belt, then over confidence kicks in with some and overtakes become more interesting. In the inter and advanced group, generally people are more self aware and don't get carried away.
Bikes vary in novice group too. You get the R1's on Maxton shocks and cartridge forks, then you get (sometimes) a dude on a Royal Enfield or a Rossi on a GS. Varying bikes and abilities means a wider range of speeds on track.
Theres a reason why insurance companies and recovery companies don't cover track days. It's because they know it's not "very very safe".
But yeah, it is a lot of fun and safer than doing track speeds on road (generally). And given all of the above, as long as you do things incrementally, be predictable / smooth. Should have a mega time. Instructors and spotters are supposed to keep an eye on people who are riding like dicks, so it shouldn't be something to overly worry about.
Tyre pressures are definitely worth playing with (pump + gauge needed). But don't go crazy (plus its October). Start off maybe down 10% and see how it goes (so if road are 36/42 then try 33/38). The sessions are short so getting heat into them may take a while as you learn the track etc
EDIT:
Topbox rack will be fine, but leave luggage off.
Have exhaust baffle in (and check in advance the DB limits, if you have a racing can you may not be allowed to proceed).
Tape up lights and mirrors. It may not help you much, but if they do have to clear your bike off the the track in bits, at least the session won't be closed for as long for everyone else as they sweep up bits of glass all over the place.
Whosthedaddy
PostPosted: 20:55 - 28 Aug 2019    Post subject: Reply with quote
EDIT:
Sorry should have stated the environmental factor is certainly a lot better than on the road and the conditions and size of the track. This makes it a safer environment
In the novice only groups there were track bikes and some very spirited riders whom were carving up the riders when bunching happens.
There is no accounting for knob heads of course.
PostPosted: 21:02 - 28 Aug 2019    Post subject: Reply with quote
EDIT:
I sort of see a nugget of truth in what you're saying but totally disagree with the essence. There has been a period in the last 15 years where track days have certainly gotten a lot more serious, the pace of inters and fast, and some sections of Novice have increased, but I've seen nothing but courteous riding on the twelve or so trackdays I've done in the last two years. I remember about ten years ago when the entire Bandit 1200 forum booked into Novice at Cadwell Park and you had about a dozen 16 stone blokes on 250kg metallic bronze bikes with gold knuckle duster heel plates diving up the inside of each and every rider in the group. This doesn't seem to happen these days.
Road bike only days are also an option, as part of the speed differential comes from people with all the gear and no idea, but I'd certainly say that the miles I do on track are a lot safer than the miles I do on the road, at least from other track users rather than my own skill or lack of.
redeem ouzzer
PostPosted: 21:22 - 28 Aug 2019    Post subject: Reply with quote
I would advise against using No Limits unless you have pace and experience, they attract people with the mindset that it’s a race and almost encourage that attitude.
Be a REAL MAN!
PostPosted: 21:52 - 28 Aug 2019    Post subject: Reply with quote
I think it's more that No Limits is the best TDO around, and so those who have experience with more than one organiser tend to gravitate to No Limits.
redeem ouzzer
PostPosted: 07:15 - 29 Aug 2019    Post subject: Reply with quote
No Limits trackdays are more dangerous than proper racing.
Discuss.
Be a REAL MAN!
PostPosted: 07:28 - 29 Aug 2019    Post subject: Reply with quote
Discuss.
They are certainly no worse than MSV or Focussed. Trackdays have got very serious these days... but hardly more dangerous than racing.
1198
PostPosted: 07:35 - 29 Aug 2019    Post subject: Re: First track day booking Reply with quote
Cool
1. Drinks / sandwiches if you have space. Not sure about tools, I never bother. If it’s even a reasonably warm day you will most likely get warm so drink plenty. Food and drinks should available from the clubhouse if you wish instead.
2. If it’s soundly secured / standard fit I would imagine so.
3. If you have the space, probably. The fuel there is expensive. You can go out to get more if you wish either between / or by missing a session or at lunch, but there’s none immediately local. Also bear in mind your bike won’t be returning the same mpg it did on the M180. (If it did either you had it pinned wide open past Brigg on your way or you are taking it really easy on track!)
4. No. Some recommend folding mirrors in so you’re not distracted by who / what’s behind, but that’s up to you.
5. The novice group ranges from slow (dude wobbling round on a Harley because he’s always wanted to, to a feller practicing on a track prepped GSX-R750 because he couldn’t get in the intermediate or fast set. Neither are a problem in my experience.
6. Never done it, but probably.
Don’t be fazed by the others, and don’t worry about what’s behind you. Take it easy and build up pace as you’re comfortable. If for any reason you want to miss a session, do it. I’ve missed sessions because it suddenly threw it down really heavily. I felt my deduction was correct when I saw a feller pushing a bike that had previously looked identical to mine back to the pits looking very sorry for himself, covered in mud with a very second hand looking bike! Most of all, enjoy it!
myvision
PostPosted: 07:56 - 29 Aug 2019    Post subject: Reply with quote
Thanks some good advice to take onboard there I'll definitely look at getting a decent foot pump and a tyre gauge.
Whosthedaddy why did you tape the speedo over?
1198
PostPosted: 08:19 - 29 Aug 2019    Post subject: Reply with quote
Same reason as the mirror folding I believe. Less distractions,
redeem ouzzer
PostPosted: 15:38 - 29 Aug 2019    Post subject: Reply with quote
I had the misfortune of doing a trackday at Cadwell in May when it was pissing it down. Never again. It's ridiculous, out of about 20 of us in the holding area there were two of us on road tyres, rest were on full wets. There is no way I am going to buy wet tyres for trackday use because
A) They are expensive
and
B) They age regardless of if you use them or not. Shelf life is about a year
In future if it's forecast to rain all day i'll simply not go. It's cheaper and getting in everyone's way because of the limitations of road tyres is zero fun.
Personally i'd ban warmers and all non road legal tyres on trackdays, if you think you are that quick you need such things then go racing.
Be a REAL MAN!
1198
PostPosted: 21:38 - 29 Aug 2019    Post subject: Reply with quote
Some companies run road bike only track days, where bikes are road legal and vans and tyre warmers are discouraged...
myvision
PostPosted: 19:01 - 25 Oct 2019    Post subject: Reply with quote
Well today was the day of my first track day and Cadwell was the chosen track and I'm glad to say that even though it pissed it down all day I still rode my bike home in one piece!!!
I took a long trip across the grass at one point and the marshal congratulated me for staying upright.
Unfortunately two lads from the group of five of us that went came off both making a mess of their bikes.
I came off track as I couldn't see a bloody thing due to the rain as it got worse as the day went on and decided I'd used all my luck for the day as I'd had a few moments!!!
All in I did five or six sessions and I will be going back hopefully in the dry next time.
Just need to buy a track bike now.
And a trailer
And a gazebo
And ..................
redeem ouzzer
PostPosted: 19:53 - 25 Oct 2019    Post subject: Reply with quote
I can’t stand track riding in the wet but it is an eye opener when it comes to control. You did the right thing calling time early. Last time I went grass tracking at Cadwell I ended up flat on my arse.
Be a REAL MAN!
The last post was made 6 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 117.11 Kb
