what is this saucery on my piaggio 50cc exhaust pipe?
ckes101
PostPosted: 21:48 - 29 Aug 2019    Post subject: what is this saucery on my piaggio 50cc exhaust pipe? Reply with quote
Hello friends and thank you for taking the time to look at my thread. I have a simple question to ask. I own a completely standard 2009 50cc piaggio typhoon which i use for work. The exhaust is a bit old and tired so i wish to replace it. But the exhausts that are showing as a pattern part replacement all look different. My one has this weird valve type thing attached where as the replacements do not. My question is this....What is this strange thing and can i do away with it should i replace the exhaust?
Similar to my My exhaust......
https://i.postimg.cc/DyrDq2Fc/typhoon-exhaust.jpg
Replacement..
https://i.postimg.cc/Lswvc72X/Piaggio-Gilera-2-T-50cc-Standard-Exhaust-1.jpg
You will see in the pictures that my type exhaust has these weird pipes on it and the recommended replacement does not. Anyway any help greatly appreciated
RhynoCZ
PostPosted: 22:00 - 29 Aug 2019    Post subject: Reply with quote
It seems like some sort of a exhaust gas recirculation system. To make it green enough.
Tracey Suntan-King
PostPosted: 22:23 - 29 Aug 2019    Post subject: Reply with quote
Sorcery.
Saucery would be ketchup, brown or hollandaise.
Mind you, I didn’t open your pics, so maybe it was a culinary question after all and now I just look like a spelling nazi-pedant.
Tracey Suntan-King
Sorcery.
Riejufixing
PostPosted: 23:03 - 29 Aug 2019    Post subject: Reply with quote
Twice.
Perhaps he's in his cups (or under them)?
Riejufixing
PostPosted: 23:06 - 29 Aug 2019    Post subject: Reply with quote
Yes. Depending on what I wanted to do with the machine if/when selling, and the cost of each different exhaust system, and whether a different nongreen exhaust system would mean adjustments would have to be made elsewhere, I might consider a nongreen exhaust. However, if the difference in price isn't too much, I'd get the standard green one. Edit: Std "green" one, OW!
Easy-X
PostPosted: 09:56 - 30 Aug 2019    Post subject: Reply with quote
Dunno why that second one is labelled 2-stroke as it's obviously a 4-stroke...
Anyhoo, the original has gas ports before and after the cat (the bulge) so not only are you dropping those you're also doing a cat delete! Note that the replacement is a free flowing exhaust so you might need to rejet... probably not if you stick with the factory airbox.
Riejufixing
PostPosted: 12:01 - 30 Aug 2019    Post subject: Reply with quote
There's a new one on ebay ( https://www.ebay.ie/itm/EXHAUST-MUFFLER-is-a-new-item-from-a-2018-Piaggio-Typhoon-50cc-1A011527-/283478795783 ), and odds and ends like heat shields are available for a lot less. Perhaps, OP, yoiu could clean yours up, give it a spray of high-temperature black and leave it at that, if it's still actually serviceable?
The last post was made 6 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 56.32 Kb
