| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 21:44 - 29 Aug 2019 Post subject: Street Triple starting problem |
It's a bit odd, not had this with any vehicle before.
Tuesday morning:
Holding the start button in, the engine cranks briefly but then stops. It'll wait a second or two, then the same again. Without releasing the button, it'll just keep regularly going "kkrrchkk.....kkrrchkk.....kkrrchkk" until button is released. (I'd put up a vid of it, but i left my bloody phone at work)
Thinking maybe the battery is struggling under load, i leave it on trickle charge all day. Get home, fires up no probs. Yay.
Wednesday morning:
Starts doing the ''kkrrchkk" thing again. FFS. So, bought a brand new battery, put it in, works fine. On the button every time, no probs. Great.
Thursday morning:
Bastid thing does it again. FUCK. I know the battery is good so i don't bother charging it this time. Get home in the afternoon, fires up, no issues!?! What?!
Keep trying, keeps starting. Good. But then, after leaving it a couple of hours, it starts kkrrchkk'ing again. Dammit.
But then i get it going by just blipping the start button once, really quickly, until there's a single short click, and it starts perfectly on the next try. Hmm.
My feeling is it's probably the starter motor, but the repeated kkrrchkk'ing makes me wonder if it could be electronics. Could it be that when it stops, it's stopping in the same position, which is shorting/earthing, and so the blipping makes it come to rest in a different place..and therefore has more ooomph before it gets to the dodgy bit? Or something else?
If i get time, i plan to take out the motor at the weekend, pull it apart and see if i can see any issues with the brushes/armature that might be causing it, but as it looks like it might be a bit of an arse of a job, hoping someone has had a similar experience of the issue, and can maybe advise a better/easier fix? Or even confirm that it will be the starter motor..?
Cheers, ears. ____________________ A Guide To Powerbands |
| jaffa90 |
 jaffa90 World Chat Champion
| Mr Hammers |
 Posted: 22:12 - 29 Aug 2019 Post subject: |
It's a 2008, 24k on the clock.
Yes, it seems to be charging ok. And once it's been running it'll start no problem. It, like me, just doesn't seem to like mornings.
edit: I read somewhere that ST's have some sort of a cutout if the battery is below a certain level of charge (which i can't find now), so i wonder if that is kicking in needlessly if the battery isn't 100% full..? ____________________ A Guide To Powerbands |
| Polarbear |
 Polarbear Super Spammer
| jaffa90 |
| BusterGonads |
 BusterGonads Trackday Trickster
| Easy-X |
 Easy-X Super Spammer
 Posted: 09:50 - 30 Aug 2019 Post subject: |
Battery swapped so...
Is it actually charging properly? After that it's either the starter motor or the sprag clutch. Remote possibility: bad earth somewhere or iffy starter switch.
Be nice to hear it if you can link us a video sometime  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Mr Hammers |
 Posted: 18:27 - 30 Aug 2019 Post subject: |
My bad, i should have mentioned, i did... 12.8v ignition off, 13.7 engine running at tickover, very brief initial drop to 11/10 when cranking. Both old and new batteries are holding their charge. Didn't want to disturb the neighbours with a steady 5k rpm test, but i'm fairly sure it's ok on the battery and charging side.
Also, the kkrrchkk is really quick... like how it usually sounds when starting up, just cutting off prematurely.
Just got home..and it works again, starts no problem, so i can't film what it's doing. The best way i can describe it though is this; imagine just hitting the start button but only for a second...and doing that at regular 2 second intervals.
If, or more likely when, it does it again i'll film it.
It's got to be either the SM, or some weird electronic thing going on, or possibly a sprag clutch issue, but i'm hoping it really isn't that.
Depending on work tomorrow, i might have a go at the SM and see how it looks. ____________________ A Guide To Powerbands |
| Sister Sledge |
 Sister Sledge World Chat Champion
| Mr Hammers |
 Posted: 19:52 - 30 Aug 2019 Post subject: |
No, it's a good question..i thought it might be that myself. The reason i don't think it is though, is that the length of the initial attempt to start, and the gap in between each are pretty precise...it's not at all random, like how you'd expect an iffy button to be. ____________________ A Guide To Powerbands |
| Pigeon |
 Pigeon World Chat Champion
| Pigeon |
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| Mr Hammers |
| jaffa90 |
| Robby |
 Robby Dirty Old Man
 Posted: 13:47 - 01 Sep 2019 Post subject: |
11 years old and 24k miles. So its the age when things start to go wrong, and the mileage where some things are wearing out.
Easy bit to check first, starter solenoid. I would just replace it, they're very cheap. If there is also a starter relay, it may be due a replacement with a generic item. That is a particular problem for Harleys, where the relays just fail after a decade. They are also very cheap.
I have also had similar trouble with worn out brushes in the starter motor. They shouldn't be worn out at that mileage, but it is possible and it does cause problems that will have replacing expensive parts hunting the problem, when the only thing wrong is a tenner's worth of carbon brush.
Also worth checking connections and cables for corrosion, condition and tightness. Crusty earthing points, loose or damaged battery cables. The sort of thing where it will carry electricity, but cause problems when you're trying to put a lot of current through it. |
| Mr Hammers |
 Posted: 15:55 - 01 Sep 2019 Post subject: |
Well...this problem is currently the least of my problems now... Started ok this morning, so took her out for a celebratory ride...
On the way home there's suddenly a muted grinding sound. Despite being in gear I've no drive. I can go up and the box but no drive in any gear. Arses.
The only good thing is I've broken down right outside a pub, and luckily for my breakdown cover policy, 5 miles from home and not 4.
It's either clutch or gearbox, and possibly connected to my previous issues.
Oh well. Fuck it. I'm off for a pint. ____________________ A Guide To Powerbands |
| Meatybeaty |
 Meatybeaty World Chat Champion
| Mr Hammers |
 Posted: 21:57 - 01 Sep 2019 Post subject: |
| Meatybeaty wrote: | Maybe time to look at your starter clutch and your front sprocket |
I'd love to..if it weren't still at the pub where i broke down.
Fucking RAC, fucking useless.
I call them, explain that it's going nowhere, send a recovery vehicle. No can do, the guy must establish that first. Ok, so wait for the patrol car. He rings up, i explain the problem, he says he'll send a recovery vehicle. Good show.
Leave the key with the chef at the pub, and get a lift home. Recovery vehicle guy rings up hours later, asks exactly where it is, who has key, etc, etc......and then says, oh i don't have a bike cradle so i'll have to just strap it to the truck. Hmmm, ok i say. BUT he says, you'll have to sign a waiver so if any damage occurs we're not liable. NO way, i say, not a fucking chance. Ok, he says, clearly put out, i'll send another vehicle with a bike cradle.
Time passes...hear nothing..give the RAC a call again..and lo, the job has been cancelled?!? Well, you wouldn't sign the waiver so we cancelled it, he says. Are you fucking kidding me, i ask, pretty fucking fuming at this point. Ok, ok we'll send a vehicle with a bike cradle...but it could take hours. FFS. The pub closes at 11, and the bike is in a car park where it can easily be nicked, not only that, there's a £15 a day charge i'll incur if it's there in the morning. Jesus.
At least the chef guy (who isn't really a biker as such, but does have an FJ in the car park) was really helpful and is going to chain it up to his bike overnight, so hopefully it won't disappear...
It's a fucking joke. Fuck the RAC, and fuck their useless dickhead contractors too. God i'm so mad right now. ____________________ A Guide To Powerbands |
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
 Posted: 22:13 - 01 Sep 2019 Post subject: |
| Mr Hammers wrote: | | Meatybeaty wrote: | Maybe time to look at your starter clutch and your front sprocket |
It's a fucking joke. Fuck the RAC, and fuck their useless dickhead contractors too. God i'm so mad right now. |
Fuck em off and get auto A.I.D.S. like me, fortyodd quid a year covers car and both bikes. IIRC they only cover bikes over tree-fiddy cc. It's always pot luck with bikes as to how busy/ near the dedicated bike recovery van is. One time was told an hour, they turned up in 15 mins for a car fault.
On the bike, told 2hrs but took 4. ____________________
'81 CG125, '97 FZS600 : '99 CBR600F4, '09 KTM RC8 |
| Sister Sledge |
| Mr Hammers |
 Posted: 21:47 - 16 Sep 2019 Post subject: |
The RAC membership was included in the insurance (Bennetts), and depending how they react to my complaint (although still haven't actually got round to it yet..) then i'll decide whether i bother with them again next year. To be fair, when i got a puncture earlier in the year, they were there in less than 10 minutes. Cheers for the recommendations, if i do get it separately then i'll probably go with one of the ones suggested.
Anyway...update on the issues...
Thankfully the lost drive problem was in fact a very simple one. The front sprocket had worked it's way off the shaft. That was it. (Good call MeatyBeaty!) Christ knows how...i know i torqued it up properly and fitted the retaining washer as i always do when i changed the chain at the beginning of this year. All i can think is that the bent over tab bit snapped off or something. Still can't figure out it would have done so though. Just going to keep an eye on it from now on. Never had that before though. Oh, and a new nut was nearly £3...ok...but the washer was nearly a tenner!! It's only a bit of pressed steel ffs!
Just glad (and that's an understatement) that it wasn't the clutch or worse, the gearbox. Obviously i would've gone down the tried and tested BCF route of welding it directly on, but i was out of gas on the mig...
As far as the starting issue goes...i searched and read up on everything relating to it that i could find, and eventually found that some people had the exact same issue on their Triumphs too (not Triples, it was a another model but i can't remember which now). One guy even took it to Triumph themselves, to see if they could figure it out. As it worked flawlessly all the time they had it, they couldn't work out what it was either.
Had intended to pull the starter motor out a couple of weekends ago, as that, apart from some electronic cause, was the only thing left i hadn't fully checked. The relay seemed to be ok when tested, but that of course was when it started working again. But, as the problem completely disappeared for nearly two weeks by then, i left it alone and hoped it had somehow sorted itself out.
Someone else who had the same problem thought it might be connected to putting the side stand down when still running and in gear (but after a while worked perfectly again), and as i have a vague recollection of doing the same thing fairly recently, was hoping it might just be that.
For the last week or so, and over the weekend and the weekend before when it was used a lot, it was fine. No sign of it at all. Until....this morning. Why does it always and only do it when i'm about to go to work?!
Left it charging through the day as all the attempts had drained it a bit, and surprise surprise, it worked fine again when i got home. If it does it tomorrow, which i bet it fucking does, i've got a 12v car battery ready to jump directly to the relay. See if that works.
Ordered another starter motor off fleabay, £103, which should arrive later this week. I'll swap it over, take the old one apart and see if there's anything obviously wrong with it, and if not, or it's something minor, fix it and chuck it back on fleabay for the same money.
Hundred quid isn't too bad, considering that a repair kit is over £70 anyway, and a new motor is around £400. Assuming that it works, of course... ____________________ A Guide To Powerbands |
| Polarbear |
 Posted: 10:48 - 17 Sep 2019 Post subject: |
Good that it wasn't anything serious with the drive. TBH I have never heard of that being a problem with stripples. Well known Fazer issue but not with Triumphs.
I expect (as a guess) you somehow snapped off the locking tab when doing up the nut. Obviously done properly it's impossible for the nut to come loose. Still, as long as you haven't fcuked the threads all is OK.
I have no idea with your starting problems though. I never had any issues with my Street triple which of course is absolutely of no help to you
Good luck.  ____________________ Triumph Trophy Launch Edition |
| Meatybeaty |
 Posted: 13:23 - 17 Sep 2019 Post subject: |
| Mr Hammers wrote: | The RAC membership was included in the insurance (Bennetts), and depending how they react to my complaint (although still haven't actually got round to it yet..) then i'll decide whether i bother with them again next year. To be fair, when i got a puncture earlier in the year, they were there in less than 10 minutes. Cheers for the recommendations, if i do get it separately then i'll probably go with one of the ones suggested.
Hundred quid isn't too bad, considering that a repair kit is over £70 anyway, and a new motor is around £400. Assuming that it works, of course... |
Think if you look on Triumphrat, they were having trouble with the 1050s, triumph did issue a replacement starter and associated thicker starter cables , think it had something to do with Back EMF, so maybe thicker Starter and Earth cables might help with an extra earth cable from the starter motor body straight to the Battery earth |
| Polarbear |
The last post was made 6 years, 293 days ago. Instead of replying here, would creating a new thread be more useful? |
