Help!
smwlexmotoech...
PostPosted: 15:58 - 01 Sep 2019    Post subject: Help! Reply with quote
Hi! So, I'm a new-ish biker, and ride a little moped. It's a Lexmoto Echo 50cc moped, and she's been perfect since I got her last Christmas.
However!
I recently had some issues starting her, so my dad and I had a look. It wasn't the carb, the fuel or the oil. We replaced the battery for a brand new one, still nothing. Eventually, it turned out to be an issue with the electric start, which we fixed.
So she starts, but she's now only traveling at low speed. I can sometimes get her up to 30mph, but most of the time, at full throttle, she's only making 10-20mph - and god forbid if she reaches a slight incline. Her speed drops drastically to around 10mph flat out, and I can't get her to speed up.
Any ideas or suggestions would be greatly appreciated. Tips on maintenance too, as I'm relatively new to the biking world and have litle to no clue about what I'm doing! Thanks again.
PostPosted: 16:31 - 01 Sep 2019    Post subject: Reply with quote
Are you 16.
If not, get a 125. A 50cc on the road is the worst thing ever.
Roller condition? How many miles you put on that bad boy?
Grubscrew
PostPosted: 20:43 - 01 Sep 2019    Post subject: Reply with quote
Check to see if the throttle cable is operating as it should, in conjunction with the twist grip, especially as it appears you’ve had the carb off.
FJR1300/CBR1000F
Evil Hans
PostPosted: 20:48 - 01 Sep 2019    Post subject: Reply with quote
Seriously though ... is the Workshop section broken?
iooi
PostPosted: 21:07 - 01 Sep 2019    Post subject: Reply with quote
Seems to be. Maybe someone needs to post how to fix it Laughing
These new posters even get warned to post in the correct section, when signing up. Even explains just what each is for....
Hong Kong Phooey
PostPosted: 22:22 - 01 Sep 2019    Post subject: Reply with quote
Have you checked the vacuum lines that operate the fuel tap, fuel filter, and breather?
If blocked or cracked it will not give enough fuel.
Riejufixing
PostPosted: 23:10 - 01 Sep 2019    Post subject: Re: Help! Reply with quote
smwlexmotoecho wrote:
a Lexmoto Echo 50cc ... Eventually, it turned out to be an issue with the electric start, which we fixed
What did you do to things inside the primary transmission (where the rubber drive belt is)?
Nobby the Bastard
Harley Gaydar
PostPosted: 09:57 - 02 Sep 2019    Post subject: Reply with quote
30 mph? Legally it isn't even designed to go that fast....
AnnaLawrence This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
PostPosted: 15:01 - 02 Sep 2019    Post subject: Reply with quote
Anna Lawrence from edubirdie.com was meant to be writing an essay for me but instead she high on crystal meth and took the opportunity to sexually molested my hamster. Thumbs Down
bhinso
PostPosted: 15:16 - 02 Sep 2019    Post subject: Reply with quote
Y U no put abusive rating then?
Nobby the Bastard
Harley Gaydar
PostPosted: 15:21 - 02 Sep 2019    Post subject: Reply with quote
The hamster gets it's action where it can.
Evil Hans This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 6 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 74.9 Kb
