Heat-resistant washers for exhaust?
Freddyfruitba...
PostPosted: 12:43 - 06 Sep 2019    Post subject: Heat-resistant washers for exhaust? Reply with quote
So I've just acquired a 2nd-hand Akra for my bike Wink, but I see from the instructions that the little carbon-fibre heatshield is supposed to fitted using heat-resistant washers, presumably to prevent it from melting?
These are missing... am not entirely sure what they look like or where I'd get some more from. Are they readily obtainable, or can I use something else comparable?
PostPosted: 12:54 - 06 Sep 2019    Post subject: Reply with quote
Any metal washer should do it assuming it isn't an ancient bike you will still be able to by parts from an Akra Supplier. I bought a replacement decal for mine once.
martin734
PostPosted: 13:17 - 06 Sep 2019    Post subject: Reply with quote
Heat resistant washers are usually made from nylon or fibre. They insulate components from heat whereas metal washers conduct heat. These could be what you are looking for.
Current bike: ST1100 "Big Red"
Freddyfruitba...
PostPosted: 13:19 - 06 Sep 2019    Post subject: Reply with quote
What, they're just ornery metal washers? How are they heat-resistant? I was assuming something based on some sort of fibrous material?
PostPosted: 13:22 - 06 Sep 2019    Post subject: Reply with quote
Silicon washers would be very poor conductors of heat. Lots on ebay.
The Artist
PostPosted: 13:45 - 06 Sep 2019    Post subject: Reply with quote
They are made from PEEK
https://en.wikipedia.org/wiki/Polyether_ether_ketone
Freddyfruitba...
PostPosted: 14:24 - 06 Sep 2019    Post subject: Reply with quote
The Artist and martin734 wrote:
PEEK
Thanks, result!: https://www.ebay.co.uk/itm/293172712537
PostPosted: 15:50 - 06 Sep 2019    Post subject: Reply with quote
So you have heat resistant washers. What is the screw that goes through them made of?
Triumph Trophy Launch Edition
PostPosted: 16:15 - 06 Sep 2019    Post subject: Reply with quote
A shape that has a very small area of contact.
Freddyfruitba...
PostPosted: 16:36 - 06 Sep 2019    Post subject: Reply with quote
Or, in theory - given that the ID of the hole in the heatshield is quite a lot greater than the OD of the retaining metal bolt passing through it (it has a wide head) - no contact at all
Grubscrew
PostPosted: 17:51 - 06 Sep 2019    Post subject: Reply with quote
Some fixings on exhausts used to have copper washers and copper nuts. May be away to go, something to do with heat dissipation
FJR1300/CBR1000F
Tankie
PostPosted: 17:56 - 06 Sep 2019    Post subject: Reply with quote
I would say brass nut as they tend not to seize .
MCN
PostPosted: 23:46 - 06 Sep 2019    Post subject: Reply with quote
FREANS
Rolling Eyes
The last post was made 6 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 76.69 Kb
