| yamahaha |
 yamahaha Derestricted Danger
 Posted: 21:55 - 06 Sep 2019 Post subject: Looking for some expertise here please |
Hi ( again )
Sorry bit long.
Ive had to sign up under a new name as I cant recall my old one
Wondering if some of you good people can give me some advice here please?
So I've got a 2009 ybr125 EFI version that I have had from new. Had been reg. serviced and looked after for a 125.
So a few months ago the odd time I would come out and go to do an electric start and the ignition light would dim. Turn it off and on again for a sec ( I work in IT ) and next time it would work fine. Used to get the odd cut out when at light and pull away. Again restarted on the button
Move on a few weeks and this time it didnt start so used the kick start and though it was the battery. 9 years old so replaced it. Been fine till now.
I came out very early this morning and turned on the ignition. Everything went out like no battery was in there. Desperate to get to work I ended up bumping it. Apart from the EML light staying on a bit longer and the rev counter going to zero then flickering for 10 secs it drove in fine. As I was half awake thought I must have done something stupid.
Roll on this afternoon and I come out of work. The bike is dead, again like no battery. Have no choice but to kick start it. The rev counter starts jumping everywhere or zero. I try and drive off as I will look at it when I get home asap. Goes 300 yards then cuts out.
Spend next 2 hours with AA who thinks its the battery but as his own admission I dont know anything about bikes. Hes trying to charge my battery with a booster pack ( Im sure this will over charge it? ) Then hes now doing it direct from his van and booster for 10 mins.
Long story short again. Bike may start from kickstart or with booster applied but does run for more than a few feet.
Its now home but dead. But every so often springs to full life ( not started ) lights, flashers, horn everything works. But touch the electric start and its as dead as a dodo again even if you turn it off and on again. Also the EML light is flashing code 39 for a injector issue but Im not sure if this is getting caused by the rectifier or battery?
Really could do with some brains please?
Cheers.  |
| grr666 |
 grr666 Super Spammer
 Posted: 22:14 - 06 Sep 2019 Post subject: |
I bought a new battery for my van recently completely unnecessarily when it turned out that actually the
100,000 mile old alternator was shot. Which then also needed replacing. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| yamahaha |
| yamahaha |
| jaffa90 |
 jaffa90 World Chat Champion
| jaffa90 |
| yamahaha |
| yamahaha |
| yamahaha |
| jaffa90 |
| yamahaha |
| jaffa90 |
| yamahaha |
| WD Forte |
 WD Forte World Chat Champion
| yamahaha |
| Meatybeaty |
 Meatybeaty World Chat Champion
| stinkwheel |
| yamahaha |
| Meatybeaty |
| Easy-X |
 Easy-X Super Spammer
 Posted: 13:20 - 07 Sep 2019 Post subject: |
It sounds like 2 separate issues:
1) Sometimes it starts, sometimes it doesn't
2) Once started it sometimes runs fine, sometimes cuts out down the road
The starting system on most bikes is usually pretty simple: battery, wiring, 30A fuse, starter switch (via ignition switch) starter relay and finally the starter itself. Trace through all these components in turn paying careful attention for any damaged wires and corroded contacts - including the fuse holder.
With regards to the clicking: is it the starter relay clicking or the starter motor? Clicking from the motor hints that not enough power is going through to engage the sprag.
On reliable running, IIRC the dancing rev counter is actually a diagnostic readout. Injector errors sound scary but I think in this situation it's more likely that the injector isn't powered correctly (which one would expect, given the story so far.)
Does sound like a degraded wiring/contacts issue. A bike might start and a contact and goes from low resistance to high resistance as current flows through it an warms things up.
Don't forget to check out basic things like clutch switches, shifter lights and kickstand cutouts! ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| yamahaha |
 Posted: 13:21 - 07 Sep 2019 Post subject: |
ok so the bikes in its ready to go mode so I start it on its kick starter, perfect. Go for a quick drive to get some petrol.
As I could see my chain was a bit loose ( i knew about this ) I thought I would pop in to the bike shop and get a quote to replace.
I tell him about this issue. He says battery. Told him its fairly new. So he does a voltage test seems fine. I tell him not to restart using the electric starter. We start it again via KS and it runs fine, he checks voltage he seems happy. I mention I think its something to do with the switch again. Turn off bike and try to start via switch. Bike dead. A minute later the bikes 'ready' again eg all the dash is bright. He puts battery booster pack straight onto starter motor. Engine starts fine. Do again. engine starts fine. So we dont think its the starter motor either.
Turn off bike to discuss chain.
I went back to bike and which is 'ready' forget and press electric starter button and dash starts flickering out. KS it and it runs enough to get me home but its erratic and rev counter all over the place.
So look at battery and terminal again. all is clean. look at positive to starter motor, its all in its rubber housing, nice any shiny.
However whenever, in this 'unready' state when I turn the bike on the battery voltage goes to zero, when bike ignition is off it at just under 12 volts if the engines not running.
Hellllllp
thanks. |
| Easy-X |
 Posted: 15:17 - 07 Sep 2019 Post subject: |
You push the starter button and everything dies... kick start it and it's fine
Solution: disconnect the starter switch and just KS from now on
Seriously though it sounds like something is shorting to ground. If it were me I'd start disconnecting things...
The starter is at the end of the chain, so to speak. If you just disconnect that and leave everything else connected does it die when you press the button? Yes? Proceed to disconnecting the starter relay, test again... work your way back as far as you can.
<addendum> tape up / make safe any loose wires, I don't want you blowing up! ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| WD Forte |
| yamahaha |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
The last post was made 6 years, 290 days ago. Instead of replying here, would creating a new thread be more useful? |
