Cheap voltmeter
ThunderGuts
PostPosted: 10:05 - 09 Sep 2019    Post subject: Cheap voltmeter Reply with quote
Can anyone recommend one? I want to have one permanently attached to my ER5 to keep an eye on the reg/rec condition. Amazon/eBay are awash with them but I suspect most are junk?!
Just wondering if anyone has experience with one they found to be reliable and fairly accurate?
Cheers
TG.
dynax
PostPosted: 10:27 - 09 Sep 2019    Post subject: Reply with quote
I bought 2 like these, https://www.ebay.co.uk/itm/LED-DC-Car-Motorcycle-Digital-Display-Voltmeter-Volt-Gauge-Meter-12V-24V-Great/392191212550?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D57923%26meid%3D10c6ae0e4b66496f9a28db91995b6698%26pid%3D100005%26rk%3D3%26rkt%3D12%26mehot%3Dag%26sd%3D233284646879%26itm%3D392191212550%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851
https://www.themotorbikeforum.co.uk/download/file.php?id=26829
https://www.themotorbikeforum.co.uk/download/file.php?id=26847
Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber
A100man
PostPosted: 11:43 - 09 Sep 2019    Post subject: Reply with quote
dynax wrote:
Did they work? Apparently they can..
'Timely grasp the state of battery voltage,'
who knew?!
PostPosted: 12:12 - 09 Sep 2019    Post subject: Reply with quote
I've fitted many similar to boats and they have all worked fine. Only replaced one that I can think of due to failure.
At that price it's a no brainer if you think you might have issues..
PostPosted: 12:30 - 09 Sep 2019    Post subject: Reply with quote
I've had one like this on my VFR for 6 years now, Still working fine. In fact, I noticed at the weekend that my battery resting voltage is dropping a bit. This thread just reminded me to bung it on the trickle charger when I get home tonight.
https://www.ebay.co.uk/itm/Mini-0-36-3-Digital-LED-Display-Voltage-Meter-Voltmeter-DC-3-2-30V-Yellow-Volt/253181643042?hash=item3af2cd4922:g:TZwAAOSwoVNaAvTZ
I epoxied it in place in the fusebox cover (which is visible from the riding position on my bike) and used the epoxy to "pot" the back of it too so it's waterproof.
Handy like that because I can take the lid off, undo the two bullet terminals I attached it with and use it for diagnostics on someone elses bike when they have a breakdown. Done this a couple of times now.
bugeye_bob
PostPosted: 13:40 - 09 Sep 2019    Post subject: Reply with quote
We use these.
https://www.ebay.co.uk/itm/12v-LED-Battery-Voltmeter-Charge-monitor-Indicator-Alternator-warning-light-lamp-/201338527109?_trksid=p2349526.m4383.l4275.c10
Falco
PostPosted: 15:03 - 10 Sep 2019    Post subject: Reply with quote
I have one built into a charging port thingy. Not sure about reliability (it's only been in week or so) but in terms of accuracy its generally within 0.1-0.3V of the value a proper voltmeter on the battery itself, which is fine just to for keeping an eye on things.
I tell you what, mathematically, I'm having it
Kawasaki Jimbo
PostPosted: 19:02 - 10 Sep 2019    Post subject: Reply with quote
bugeye_bob wrote:
I fitted a similar one to my R1 after fixing a charging fault but I found it too distracting. Symptoms of under-charging will manifest themselves before they leave you stranded, you just need to recognise them. Poor starting, battery unexpectedly in need of mains-charging. I'm less sure of over-charging fore-warnings but a reg/rec burning smell might be one. In short, I don't think you need one and I like the minimalist aspect of bikes. I'm not a fan of modes'n'sh!t either.
WD Forte
PostPosted: 14:22 - 17 Sep 2019    Post subject: Reply with quote
Just got one of the ones Dynax mentions
and comparing it to one of my meters, it looks pretty accurate for bike use
https://imgur.com/guYnbZk.jpg
bikers smell of wee
STONEY!
PostPosted: 18:22 - 17 Sep 2019    Post subject: Reply with quote
5 of us went on a 5500 mile trip around europe on cb500's knowing that they are common for reg/rec failures we bought these
https://www.ebay.co.uk/itm/DC-4-5V-30V-LED-Digital-Display-Voltmeter-Voltage-Gauge-Panel-Meter-For-Car/382801348018?hash=item5920bd05b2:m:momI_UtUcRZXpbry0bU16ow
did the trick fine and survived a torrential rain storm, one bike did have a reg/rec failure and this alerted us to it before it did any damage so well worth the 99p!
evilzed
PostPosted: 19:16 - 19 Sep 2019    Post subject: Reply with quote
I fitted this on my bike the other week, it's a naked so no fairings to mount the other styles easily and I needed some USB ports for charging
https://tinyurl.com/y2adrpf9
WD Forte
PostPosted: 21:26 - 19 Sep 2019    Post subject: Reply with quote
They're quite nifty these things and cheap too.
I have a twin usb and voltmeter type installed in a blank switch
plate on my cars centre console.
bikers smell of wee
The last post was made 7 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 74.76 Kb
