| adengtg |
 adengtg Scooby Slapper
| Nobby the Bastard |
| adengtg |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 17:34 - 09 Sep 2019 Post subject: |
How old is the battery and what's its condition (I mean Amps/the ability to spin the crankshaft, not Volts)? Also, have you cleaned the starter button lately? Is the kill switch (any of them) in alright working order?
Bypassing the solenoid means you put direct power from the battery into the starter, so it should spin/even start, if do do this. If it doesn't start, I'd say the starter motor is either stuck, or it needs a fresh set of motor brushes.
You could knock the starter motor loose, if that's the issue. The handle of a big screw driver should do the trick. Don't use a hammer or any metal tools to knock metal on metal, you'll chip whatever you're hitting.
ALSO, check your earth points. The starter motor earth point would be the first one to check, as I do know for sure, there must be a place, where the starter motor is grounded. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Nobby the Bastard |
| Bhud |
 Bhud World Chat Champion
| Nobby the Bastard |
| steve the grease |
| RhynoCZ |
| Easy-X |
 Easy-X Super Spammer
 Posted: 19:26 - 09 Sep 2019 Post subject: |
Take the battery out and charge it  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
| Fizzer Thou |
| Nobby the Bastard |
| Nobby the Bastard |
| Easy-X |
| Nobby the Bastard |
| Fizzer Thou |
| Nobby the Bastard |
| MCN |
 MCN Super Spammer
| steve the grease |
 Posted: 19:00 - 11 Sep 2019 Post subject: |
I call it the starting triangle. The vehicle won't start. Is it the starter, is it the battery , is it the charging system?
The first thing to isolate is the charging system, if charging the battery makes it start, it could be the charging. Does it then start in the morning...... If yes it's the charging system( battery was flat -now good) , if no then it's probably the battery ( battery was charged - now flat) . Charge it up again , leave it overnight , if it's always flat in the morning it's the battery. Then and only then start looking at the starter. Without a known good charged battery , you haven't anything to check it with anyway. Short the solenoid connections (Careful) if it goes, it's the solenoid , if not it's the starter motor itself.
Probably. |
The last post was made 6 years, 145 days ago. Instead of replying here, would creating a new thread be more useful? |
