ZX-7R seat lock key
Phoenix
Twisted Firestarter
PostPosted: 07:17 - 12 Sep 2019    Post subject: ZX-7R seat lock key Reply with quote
Anyone know if the seat lock on the ZX-7R is an actual lock or can it be turned by any Kawasaki key like Honda ones? My ignition and tank use the same key but the seat lock doesn't turn and i'm not sure if its just jammed or its keyed differently, if the latter then I know I need to buy one with a key.
doggone
PostPosted: 07:27 - 12 Sep 2019    Post subject: Reply with quote
It would have been the same key originally, either the seat or ignition might have been changed or it's stuck due to not being used or corrosion. Maybe it's broken and been held down with a bolt unless you know different.
sickpup
Old Timer
PostPosted: 22:00 - 12 Sep 2019    Post subject: Re: ZX-7R seat lock key Reply with quote
Both are keyed locks unless worn out but both have less pins than an ignition lock.
You missed us again then?
Phoenix
Twisted Firestarter
PostPosted: 21:57 - 17 Sep 2019    Post subject: Reply with quote
Looks like i'll have get a new one with key or figure out another solution then.
Yeah, deeply sickpup, haven't had a bike for 4 years since i left the land of hope and glory.
RhynoCZ
PostPosted: 14:17 - 18 Sep 2019    Post subject: Reply with quote
You may buy blank Kawasaki keys on ali-china-express.
PostPosted: 19:23 - 18 Sep 2019    Post subject: Reply with quote
If you can get the barrel out, you can rearrange the wards (or file the outsides off) so the current key fits. There are plenty howtos on this. They are not complex locks.
Phoenix
Twisted Firestarter
PostPosted: 20:47 - 25 Sep 2019    Post subject: Reply with quote
Thanks stinkwheel,
I disassembled the lock and it only had 3 wafers in it, 1 was flush, the other two out of line by equal amounts above and below the surface so swapped those 2 around and it's now keyed to the same key as the rest of the bike Thumbs Up
The last post was made 7 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 52.02 Kb
