11.4V full revv - Piaggio fly 125 - REG/Rec or Stator
mysterdee888
PostPosted: 10:44 - 12 Sep 2019    Post subject: 11.4V full revv - Piaggio fly 125 - REG/Rec or Stator Reply with quote
Hi guys I'm new to the forum and I have signed up for a little advice relating to my piaggio fly 125.
I bought it off a cowboy for £800 only to find that it had a few problems that where not apparent at the buying stage.
After I bought the bike the battery died within a couple of hours. I rang the guy who sold me the bike now he basically told me to funk off.
I nearly did. But instead I got down to solving the problem.
I 1st bought a new battery and a charger and took the bike out for a few hours and the same thing happened. So I bought a multimeter and took readings.
The readings indicate either a bad R/R or a bad gen but I've not stripped the panels yet to test them. I'm hoping a more experienced mind may shed a little light on the actual problem which is why I am here. Would you say these readings show a bad reg/rec or a bad gen/stator. It could just be an earthing issue also.
But from these readings what would you suggest.
The bike is a 2010 piaggio fly 125 with 10k miles on clock , brand new battery fully re-charged every day.
Bike off: 12-13v
Bike on: 12-13v
Bike idle: 11.4v
Bike revving 1-4k: 11.4v no change
Also had a bad main beam light that went out on bumps and back on with a smack on top.
I changed the bulb and cleaned the terminals. Noticed a black sooty point with melted plastic around 1 terminal. Cleaned it up put in new bulb. No problem since...
What do you think guys
Thanks for any info
Meatybeaty
PostPosted: 11:28 - 12 Sep 2019    Post subject: Reply with quote
Looks like your on the right track, worth checking the stator and the Reg/Rec, dont know these scoots but have a look at this
mysterdee888
PostPosted: 11:41 - 12 Sep 2019    Post subject: Reply with quote
Thanks for the reply m8.
I guess 1st off i should strip down n test the reg/rec and stator before buying any parts.
Im hoping its just reg/rec.
Thanks.
Meatybeaty
PostPosted: 11:48 - 12 Sep 2019    Post subject: Reply with quote
Can PM you the manual if needed
mysterdee888
PostPosted: 12:25 - 12 Sep 2019    Post subject: Reply with quote
ok m8, thanks, what manual is it. cheers.
Meatybeaty
PostPosted: 12:43 - 12 Sep 2019    Post subject: Reply with quote
PM'd, its the only one I have for that style bike
mysterdee888
PostPosted: 17:53 - 12 Sep 2019    Post subject: Reply with quote
Sure m8, send me the link, cheers
The last post was made 6 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.51 - MySQL Queries: 13 - Page Size: 50.82 Kb
