Split link on chain safe on a bike with decent power?
Gazz
PostPosted: 22:06 - 14 Sep 2019    Post subject: Split link on chain safe on a bike with decent power? Reply with quote
I've asked on another forum if a certain chain was suitable for my bike, the people on the other forum say that you should not use a split link on anything above a 125 and the chain should be riveted. Just looking for more of a conclusive answer if I split link is safe to use.
Bike is Triumph 1050.
PostPosted: 23:39 - 14 Sep 2019    Post subject: Reply with quote
Had one on my turbo bike *shrugs*
kgm
PostPosted: 00:25 - 15 Sep 2019    Post subject: Reply with quote
Why bother? It's not hard to rivet it.
If it's just for a short journey I wouldn't worry but I'd prefer a proper rivet long term.
RhynoCZ
PostPosted: 00:47 - 15 Sep 2019    Post subject: Reply with quote
Many manufacturers say the split link is alright for up to 500cc 4 stroke engines. Who told you the chain on anything above a 125 has to be riveted?
Is it safe to use the split link on bigger (meaning above 500cc/45Nm) engines? No, it is not. Sure, if don't accelerate hard it will be alright even on the liter superbikes. But at some point in the future, when you decide to twist the throttle wide open and have a blast, that spit link might/will split. I have seen this before.
TL; DR: Rivet the chain on anything above 500cc, just to be safe. No special tools required.
mentalboy
PostPosted: 03:45 - 15 Sep 2019    Post subject: Reply with quote
Must be a Zed1100 owner thing, mine ran on a split link for a while, no kittens died.
Make mine a Corona.
PostPosted: 11:47 - 15 Sep 2019    Post subject: Reply with quote
My opinion on split links is that I had one snap a few years ago on an R6.
mentalboy
PostPosted: 11:55 - 15 Sep 2019    Post subject: Reply with quote
Are you getting confused and meant Bodytard's R6? Laughing
Make mine a Corona.
PostPosted: 11:56 - 15 Sep 2019    Post subject: Reply with quote
The R6 belonged to G. Laughing
Grubscrew
PostPosted: 15:26 - 15 Sep 2019    Post subject: Reply with quote
Nothing wrong with a split link, my son has one on his cb500x,and we’re on a touring trip in Western Europe, too many scare stories about. Fit it the correct way and you can even wire it to the link if your worried.
FJR1300/CBR1000F
iooi
PostPosted: 15:27 - 15 Sep 2019    Post subject: Reply with quote
RhynoCZ wrote:
if don't accelerate hard it will be alright even on the liter superbikes. .
No issue on drag bikes... I think they tend to accelerate hard every time Wink
PostPosted: 16:10 - 15 Sep 2019    Post subject: Reply with quote
If you're worried about using a split link, don't use one. Laughing
PostPosted: 16:33 - 15 Sep 2019    Post subject: Reply with quote
I suppose I wouldn't if I had the gear to fit a riveted one but I wouldn't overly worry if I had to fit a split link as a temporary measure.
It would probably end up like those temporary puncture repairs that are forgotten about for the life of the tyre, forgotten. Laughing
Triumph Trophy Launch Edition
ThatDippyTwat
PostPosted: 08:48 - 16 Sep 2019    Post subject: Reply with quote
I'll rivet if I can, but in a pinch I've used one on a VFR750 - Not that powerful, but is a lardy beast.
blue_painted
PostPosted: 12:33 - 17 Sep 2019    Post subject: Reply with quote
Yeah but ... the power is carried from pin to pin by the side plates, not the fastening at the head of the pins, so as long as the side plates are in place why would it make any difference?
Okay, so the spring clip might break and then the side plate work off the pins ... maybe ...
GP-100 -> CB250RS -> CBX550F2 (pause) KR1S -> RD350YPVS -> ZX6-R (pause) CD200 ->Mash 400 -> T100 (current) & (R1100RT scrapped pile o' shite) (CB250 Nighthawk - SORN in shed) Meteor 350 (current)
Riejufixing
PostPosted: 14:19 - 17 Sep 2019    Post subject: Reply with quote
Quite. Note that some people put the clip on the wrong way around, so it could be dislodged by a stone or some other piece of debris.
Old Git Racing
PostPosted: 15:19 - 17 Sep 2019    Post subject: Reply with quote
Used split links on the race bikes no problem. Used to put silicon on the link to prevent stones etc hitting it and a handy visual reference to check it was ok.
OGR
blue_painted
PostPosted: 21:31 - 17 Sep 2019    Post subject: Reply with quote
You'd have to be bastard unlucky to have that happen - give how small a target the spring clip is ... but I suppose if it can happen it will happen.
Sister Sledge
PostPosted: 06:51 - 18 Sep 2019    Post subject: Reply with quote
With split links remember too that some bikes use chain guides and rollers. When moving the bike backwards the clip can undo when going through a guide (have done it on a trials bike).
CCM 404 DS
MCN
PostPosted: 14:57 - 18 Sep 2019    Post subject: Reply with quote
Yes the load moments are mostly in a radial direction transmitted through the pins and side plates.
But..
The pins flex under load. This allows some of the energy to migrate onto the side of the side plates.
Even though it's a small force.
It's the frequency of loading-unloading that frets the parts in contact with each other.
Continuous side plate loading will wear the spring clip and the pin retainer grooves.
Riveted links are better at coping with that side load and therefore can easily last the life of the chain's .
Courier265
PostPosted: 22:18 - 26 Sep 2019    Post subject: Re: Split link on chain safe on a bike with decent power? Reply with quote
That's bollocks.
I've been using split links on 250's for decades.
Also using Split links on my CBF500, however the split links now need a special tool to compress.
CBF500 - 2 x Inazuma 250
Skudd
PostPosted: 22:23 - 26 Sep 2019    Post subject: Reply with quote
Use it as a rule of thumb for up to a 500cc, above that I would not use one myself, but there again I now have a shaft drive.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:44 - 26 Sep 2019    Post subject: Reply with quote
Can you stop referring to my penis as your shaft drive?
Triumph Sprint ST 1050
Nobby the Bastard
Harley Gaydar
PostPosted: 22:47 - 26 Sep 2019    Post subject: Reply with quote
Anyway, all jokes aside...
Ive fitted split pins on bikes as a temporary measure only to discover that the crocodile clip is missing entirely when I've gone to replace the chain.....
trevor saxe-coburg-gotha
PostPosted: 09:00 - 27 Sep 2019    Post subject: Reply with quote
I actually don't think he can any more. I do remember a time when I honestly thought he could. Alas, and indeed alack, I fear the habit has become far too engrained. I therefore offer an alternative suggestion: You embrace this quirk of character and learn to think of it as a term of endearment - perhaps even a badge of honour.
almostthere
PostPosted: 18:24 - 28 Sep 2019    Post subject: Reply with quote
You could always get bodytard to weld your splitlink Thumbs Up while he's there he could do your sprocket as well for extra security Smile
Beer, It's the reason I get up every afternoon
www.mfairco.uk
The last post was made 6 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 127.81 Kb
