Virago XV535 generator coil prob
dekip
PostPosted: 15:34 - 15 Sep 2019    Post subject: Virago XV535 generator coil prob Reply with quote
Last night i had an issue and let my battery goes down. Don't ask why.Smile
Anyway, i had to use cables to start it up again. After a ride of some 20km when i get back home i tried to start it again, it failed. After a 20km ride, battery was still empty enough to start the engine. After charging it properly i check my mechanic to see what he can say, about it.
He check charging the battery and rec/reg unit and said that generator coil isn't working properly. On 1/3 of engine running, it was about 12V on battery. Over 1/2 and more throttle, it goes to 14V and above.
He suggests to change this coil. Question is where to buy it. I checked it on ebay and aliexpress and noticed different prices. Or should i try to find someone to wind it again.
Or anyone suggests something else. I am all ears.
Long time reviewer in computer magazine.
That include all wireless devices, SBC and microcontrollers. When my brain get stuck, all that helps is ride.
My bikes: MZ 175SE (1967), Yamaha Virago XV535 (1993) and TVS Apache (2008)
PostPosted: 16:27 - 15 Sep 2019    Post subject: Reply with quote
What prices are you getting quoted?
WD Forte
PostPosted: 18:04 - 15 Sep 2019    Post subject: Reply with quote
Fowlers wants £333.54 for a new XV535 stator
which is absurd.
A quick look on Ebay sees LN parts wants £66.99
and this place wants £34.99!! ( posts wordlwide they say)
Jeez!, not sure I could rewind it myself for that and why would I bother?
Link
https://www.ebay.co.uk/itm/Replacement-Stator-Generator-Magneto-Assembly-for-Yamaha-XV-535-Virago-87-01/302956512881?epid=25025215873&hash=item46899d8671:g:6D0AAOSwapdb6rHz
Changing it is a pretty simple DIY job, lots of info on tinterweb
probably best to get one of these too
https://www.ebay.co.uk/itm/Yamaha-XV535-Virago-1988-2003-Alternator-Stator-Generator-Engine-Cover-Gasket/112784158303?hash=item1a4275ae5f:g:zLcAAOSwmC5a~VKk
bikers smell of wee
PostPosted: 21:16 - 15 Sep 2019    Post subject: Reply with quote
At £35 that is really a no brainer.
dekip
PostPosted: 23:00 - 15 Sep 2019    Post subject: Reply with quote
But according to symptoms, coils are bad?
I have read about it, that they just get dead. But not to work on higher throttle, and don't work on lower.
WD Forte
PostPosted: 23:44 - 15 Sep 2019    Post subject: Reply with quote
Your 'symptoms' are a bit vague ( nejasan/нејасан )
and you don't mention any testing you've done
other than some voltages
Test the stator, Test the RegRec plus related cabling and connections
before buying anything
bikers smell of wee
jaffa90
PostPosted: 23:49 - 15 Sep 2019    Post subject: Reply with quote
As said what are the 3 a/c alternator output readings?
The last post was made 7 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 52.57 Kb
