Reluctant Starter Motor on Honda CBF500
Amber Phoenix
PostPosted: 16:25 - 17 Sep 2019    Post subject: Reluctant Starter Motor on Honda CBF500 Reply with quote
Wife's got a 2006 CBF500, which has been well used over the years and is now up to 65k. This morning starter motor decided to not turn over. Ignition on, choke out, press starter button, nowt, no cranking at all. Gave it a couple of bashes with a bit of wood and it freed up, and started the bike instantly. It did this once before several months ago, hence knew plan of action. Was a spot cooler this morning, dunno if related. But having done it again today, I'm starting to wonder about the reliability of this motor now.
How common is such behaviour for a starter motor?
Is it the sort of thing where it'll just do this once in a while and I'm best just putting up with it.
Or is this a symptom of dying starter motor that'll likely leave my wife stranded somewhere on a cold day?
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
Meatybeaty
PostPosted: 16:42 - 17 Sep 2019    Post subject: Reply with quote
Maybe just a matter of taking it out strip and clean, check the brushes
Tankie
PostPosted: 16:56 - 17 Sep 2019    Post subject: Reply with quote
Sounds about right.
PostPosted: 19:07 - 17 Sep 2019    Post subject: Reply with quote
Might even be carbon debris blocking the commutator. Try bumping it backwards slightly in gear instead if hitting it next time, that'll move it round a bit. Solution is the same though.
Amber Phoenix
PostPosted: 20:03 - 17 Sep 2019    Post subject: Reply with quote
Cool, sounds like I'll be stripping it down at the weekend to take a closer look. Probably worth picking up some replacement brushes to slap in whilst I'm doing the job.
Anyone know what bits I'm likely to need / should replace anyway?
Brushes? Two yes? Both same? Worth replacing brush holder ring bit?
Of course, I could pull it apart, inspect it and see what I need, but my wife's using bike every day for work, so don't fancy taking it off road for long.
Yamaha FZ6 S2 2007
The last post was made 7 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 43.99 Kb
