ybr125 front wheel
Cavallo
PostPosted: 18:31 - 19 Sep 2019    Post subject: ybr125 front wheel Reply with quote
Hi, I removed the front wheel of my YBR125 2016 to replace tyre and I got in doubt about the axle shaft. the shaft nut was on the left side but on the manual shows that the nut is on the right. does this make any difference to the bike? Question
Thanks
jaffa90
PostPosted: 21:11 - 19 Sep 2019    Post subject: Reply with quote
Any good? The custom model shows the same. WDForte on here should know.
Riejufixing
PostPosted: 21:59 - 19 Sep 2019    Post subject: Re: ybr125 front wheel Reply with quote
The nut is on the nearside AFAIK (edit: nope!)
WD Forte
PostPosted: 00:19 - 20 Sep 2019    Post subject: Reply with quote
Yep, You'd think I would by now having done so much on a local guys bike but I cant recall offhand.
( sounds of rummaging)
I do have his manual here though and in the
'Brakes wheels and Final drive' section it shows the nut on the RH side looking forward as per the image above.
bikers smell of wee
steve the grease
PostPosted: 13:19 - 20 Sep 2019    Post subject: Reply with quote
I'm not sure it really matters, on my bike it's better to put it in from the speedo drive side, so that the speedo drive is held in place while you try and align the wheel/ disk / fork leg/ the hole for the spindle and all with only 2 hands! Other wise the speedo drive drops out just when you get it all lined up........
Cavallo
PostPosted: 15:30 - 20 Sep 2019    Post subject: Reply with quote
Hi again,
Met a friend who own a ybr same annum and checked his. Axle nut is on the left side as well, same as mine. Thr shaft needs to be inserted from the disc brake side. Thx guys
WD Forte
PostPosted: 17:22 - 20 Sep 2019    Post subject: Reply with quote
Cavallo wrote:
Hi again,
Sounds like the two of you have it wrong then
Read Steve the grease's post
bikers smell of wee
Cavallo
PostPosted: 19:05 - 20 Sep 2019    Post subject: Reply with quote
WD Forte wrote:
Cavallo wrote:
Hi again,
Saw another ybr parked and had the nut cover missing and also the nut was on the left side. Ybr model year 2008.
WD Forte
PostPosted: 23:47 - 20 Sep 2019    Post subject: Reply with quote
Three
bikers smell of wee
The last post was made 7 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 58.89 Kb
