YBR Ignition switch
WD Forte
PostPosted: 00:56 - 20 Sep 2019    Post subject: YBR Ignition switch Reply with quote
Got this guys 2010 YBR dropped off here by a recovery truck
last weekend after a total electrical failure.
He was riding through central Bristol when it suddenly stopped and
all lights went out.
Main fuse OK, power to red wire in 4 way connector in headlamp
and got power back on Brown when ignition switch turned on
Huh?
Started to check and fiddle with 4 way connector terminals as I'd fitted these
as he bought an aftermarket switch early this year.
They looked fine but noticed the power out on Brown was intermittent
further fiddling with red wire caused it to come off in my hand!.
Whipping out the ignition switch showed the solder joint had failed
on the pad under the switch
( removing the switch was easy as I'd had to cut the security bolts off
when changing the switch and I used cap head bolts when fitting the new one)
Dodgy soldering and poor strain relief perhaps? but as he was eager to get going again
I didn't get too forensic and just trimmed and resoldered the cable back on the pad
and gave it couple of new ties to hold it securely.
I removed the 2 unused cables while I was at it.
Those contacts were NC and open at power on when they should close and looking at the pic later
I wondered if the two brass pads above were NO and I could have used them.
However bikes running tickety boo again and he's happy.
Moral of this story:
If you buy a cheap after market YBR ignition switch
pop the end cap off and check the pad soldering and cable strain relief
before you fit it.
Also, check the lower contacts close at turn on ( NO)
If they dont, see if the brass pads can be used or just strap the
Black( or light green) and Black/White wire together at the connector.
https://imgur.com/4BN9zej.jpg
bikers smell of wee
Meatybeaty
PostPosted: 04:16 - 20 Sep 2019    Post subject: Reply with quote
Good investigation matey Thumbs Up
Easy-X
PostPosted: 11:04 - 20 Sep 2019    Post subject: Reply with quote
Applies to any pattern shit Sad Even something as simple a plastic panel usually has moulding flash remnants for your OCD to obsess over Laughing
Fizzoid
PostPosted: 11:16 - 20 Sep 2019    Post subject: Reply with quote
I'm in a few Facebook YBR groups and these cheap ignition switches always seems to cause issues
Rogerborg wrote: It'd certainly make it easier to ego-find my own posts on pages, given the number of fags (gay like traps) who insist on putting my name in their .sig
steve the grease
PostPosted: 11:26 - 20 Sep 2019    Post subject: Reply with quote
A very useful post , a knowledge base there for others in the future.
And we used to complain about Lucas stuff. Lucas was described as 'The Prince of darkness' . Back then it was ( mainly) crap materials , now it's materials and workmanship.
WD Forte
PostPosted: 12:41 - 20 Sep 2019    Post subject: Reply with quote
To be fair, the switch itself is fine as a main power switch apart from some not having the secondary function which can easily be bypassed.
The problem was more assembly related and when you compare
£128 for an original lock set to £20 for an Ebay one its quite compelling
bikers smell of wee
The last post was made 7 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 47.87 Kb
