Speedometer illumination mod? (Yamaha TDM 850)
jimiscorpio
PostPosted: 14:06 - 22 Sep 2019    Post subject: Speedometer illumination mod? (Yamaha TDM 850) Reply with quote
Hello everyone,
I'm a total beginner here, just got my license and just bought my first bike. I have a Yamaha TDM 850, 1998.
I've got plenty to find out about but one of the most pressing is that the instrument panel on this bike is not illuminated or even reflective.
Has anyone got advice of what to do? I was thinking of a little led strip light perhaps. It's basically impossible to read at night, you can't even see the speed.
Or would is be possible to replace the clocks with a modern one? Is it possible to connect a "generic" counter on there or is that just a really dumb question?
Thanks in advance!
J
P.S. I'm also unsure about the terminology here, did I mention that I'm super green?
The correct answer is probably no.
PostPosted: 14:22 - 22 Sep 2019    Post subject: Reply with quote
Just replace the bulb underneath...? Unsure on the TDM but its likely just got a blown bulb in there.
trevor saxe-coburg-gotha
PostPosted: 14:23 - 22 Sep 2019    Post subject: Reply with quote
Clocks of that age will have small bulbs behind them - I've had two bikes that have needed replacement bulbs, so they do definitely fail with age. However, it does seem a bit odd that all of them have gone (there will be at least two, I would've thought - one for the speedo, and another for the tacho). If you're not used to taking instruments like this apart, it's best to get a bike mechanic to do it. It's a relatively easy job for those who work on bikes, and the likelihood is that they'll have some bulbs knocking around ready to fit. Mine did, anyway. My only other comment is that it seems a bit unlikely that all the instrument bulbs have gone at once - perhaps a fuse has gone, and in fact, the bulbs are still working. If you can find your fuse box, it might be possible to remove them and see if any are blown - it's easy to check these once they're pulled out of the board.
Replacing the clocks strikes me as a pretty drastic first move - not least because they'll be expensive and your bike's mileage will then be incorrect.
PostPosted: 14:28 - 22 Sep 2019    Post subject: Reply with quote
Just change the bulb(s).
https://www.bike-parts-yam.com/yamaha-motorcycle/850-MOTO/1992/TDM/TDM850/SPEEDOMETER/27_2745-2745/B39/0/7154
https://www.bike-parts-yam.com/thumbs/y/images/27/2745-2745/900_900/FIG_39.PNG
doggone
PostPosted: 14:29 - 22 Sep 2019    Post subject: Reply with quote
Sometimes the bulbs are in quite chunky rubber holders you can access from below without too much dismantling.
Vibration is the issue they do often fail.
redeem ouzzer
PostPosted: 07:43 - 24 Sep 2019    Post subject: Reply with quote
Don’t need clock lights for MOT.
Be a REAL MAN!
Easy-X
PostPosted: 10:07 - 24 Sep 2019    Post subject: Re: Speedometer illumination mod? (Yamaha TDM 850) Reply with quote
Are you also a vegan?
I would imagine the bulbs went one at a time and the previous owner never bothered sorting it. Now the nights are drawing in the problem is more apparent.
If you're going to all the bother of dismantling the clocks you may as well swap the filament bulbs for LED.
The last post was made 6 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.5 - MySQL Queries: 13 - Page Size: 52.25 Kb
