| archyrcv |
 archyrcv Derestricted Danger
 Posted: 13:02 - 19 Sep 2019 Post subject: 2006 rs 125 , 34 mm carb, Running problems |
Hi iam new on here but not new to bikes.
i have rebuild a 2006 rs125 that was sold to me in boxes. the engine has been rebuilt by others but works absolutely fine.
so she starts first time every time. choke works perfect
she idles very nicely too
she revs right up through to about 8/9k
the power valve works fine and is free and clean
the cdi black box has had the bridge removed ( which made a big difference
the 34mm carb was a puzzle at first and this is what iam working with now
main jet 155 with atomizer 266
needle k57 on the top notch ( was on the middle notch before but i moved to the top before i de-restricted the cdi module)
float needle and seating 300
choke 60
idles / pilot 36
it has new fuel line
new plug BR10
the carb is clean
mixture screw is 1 & 3/4 out from shut
the cdi box for the powervalve seems to be working as the blade movement is good too
so to clarify she pulls well right up to about 7k and only has a top speed of 50mph
the carb filter was broken so i removed it , it has a filter on the vacum tap on the fuel tank so not worried about the fuel.
i have removed the air box nose rubber too
can anyone help with this , my fireblade has 4 carbs and ive set them up in 30 mins this rs is doing me nut in.
she looks amazing and is complete now i just need to sweak her a bit ____________________ darren jones |
| P.addy |
 P.addy Red Rocket
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| archyrcv |
| Easy-X |
 Easy-X Super Spammer
 Posted: 14:15 - 20 Sep 2019 Post subject: |
Fine until high revs, then splutters. Needle adjustment hint at rich mixture over lean
I'd say there's either a problem with the carb at wide open throttle or some restriction in the air/exhaust flow. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
 - Super Spammer
| archyrcv |
| P.addy |
 P.addy Red Rocket
| archyrcv |
| archyrcv |
| redeem ouzzer |
| archyrcv |
| stevo as b4 |
 Posted: 00:00 - 22 Sep 2019 Post subject: |
Blue is right!
That sucker needs to go on a dyno to sort out, and optimise the set up for your engine and modifications.
Oh and thank you for this thread, as reading it makes me realise that although I know absolutely fuck all about two stroke engines, and also having a 125 with extensive modifications, the one thing I'll never to is come on here asking for advice on how to fix it or set it up.
I'd rather pay a good tuner and dyno operator to do that for me, than risk sounding like a totally clueless fool. To me that's worth several £££.  |
| archyrcv |
 Posted: 19:13 - 22 Sep 2019 Post subject: |
thanks for your input steve , but to be fair pal that isnt a way that i was brought up think. every day is a school day and if iam able to fix this issue then its a result even with help.
i dont like to be beaten
| mentalboy |
 mentalboy World Chat Champion
| archyrcv |
 - Super Spammer
| mentalboy |
 Posted: 23:37 - 22 Sep 2019 Post subject: |
| archyrcv wrote: | hi
not i received the bike in pieces , i rebuild it up from a carcass all bar the new engine rebuild
it was running lovely in neutral from the word go. til i took it for a run .
i found it wouldnt reach 4k then possibly got to 5k
so did more research then did the cdi mod
this mad a nice difference . and now iam thinking down the road of over fueling a couple of guys have said this has happened to them so ive ordered a 140 main jet
the airflow has me a little stumped . unless the foam filter is an issue which i dont think so to be fair. she runs better with the snorkel gone but i think removing the foam from the airbox will give to much air
i wish i had a dyno close as it would benefit from it
have you had anything like this |
I loved the two strokes I had but they were a proper pain in the butt when it came to troubleshooting issues and they were just simple pre-80's machines so no fancy gizmo's or mods to throw things out of whack.
Two strokes are really simple machines but they aren't very forgiving to random changes. Four strokers don't usually consider that a two stroke is highly dependent upon it's crankcase compression as well as it's top end compression.
My rule of thumb when playing with the carb settings was to document everything on it when it was running well before tinkering with it, so that I could always put it back to standard.
Reed valves need to be blemish free on their contact points, I've seen some that some fool had pried open with a screwdriver to see if they were working properly and had bent one of the reeds, only slightly and tricky to find but enough to upset the machine big style.
Just changing the angle and length of downpipes can result in poor back pressure issues, let alone messing around with the silencer.
My workshop skills were more trial and error (rubber band and chewing gum style ) and trial told me that unless I'd been regularly tracking the top end compression on a two stroke then doing a one time test might be an aid but wasn't much help unless figures were noticeably adrift. It pays to pull the plugs and record the compression figures on a regular basis to serve as a future aid when troubleshooting.
As it is, you've gone balls out with jets, mixture, pressure in, pressure out and timing that I wouldn't know where to definitively start, although I might be tempted to start with a bigger main jet but I would be more inclined to pay someone else who really knows what they are doing and make it their problem!
Four strokes are a dang sight more forgiving when it comes to messing with! ____________________ Make mine a Corona. |
| archyrcv |
 - Super Spammer
 Posted: 22:31 - 23 Sep 2019 Post subject: |
| archyrcv wrote: | Hi
well i have a reading of 122psi on the comp test. its seems ok
i will wait for the new main jets and start from there i think.
i do document every little change and it seems like iam heading in the right direction as like i said this was a project bike that i bought so ive never known it running any other way than this.
i think i will start with the main jet now when i get them and document how it goes. and work from there
i am still intrigued about a guy on youtube converting his 2007 to full power and his jet setup was vast. i know the weather and atmospheric pressure comes into play but its a million miles off where the standard setup is
fingers crossed with the new jets anyway
regards |
The thing is, as standard you’d see 80mph on the clocks restricted and 100mph plus derestricted.
If you’re only seeing 50mph, something in the fiddling you’ve done is way out if compression is that good. Can you not do a plug chop and post a pic up?
i.e, standard, non iridium fresh plug, rag it as much as you can then cut ignition and whip the clutch in as you pull back up to the drive. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| archyrcv |
| stevo as b4 |
| mentalboy |
 - Super Spammer
| archyrcv |
The last post was made 7 years, 2 days ago. Instead of replying here, would creating a new thread be more useful? |
