Riding without elecy..
retrofly
PostPosted: 16:31 - 05 Nov 2002    Post subject: Riding without elecy.. Reply with quote
At the mo my bikes battery dosnt seem to be working properly. The starter motor aint working so i have to bump start it, the lights are always flickering, if they are on. None of the "idiot" lights work and nither doees, the indicators/rev conter/temp gauge.The only time stuff does work is when i pull in the break leaver???. Why is this happening and will this cause damage to my bike, ie no oil getting to the engine, not proper fule management, ect. Also theres no more power in the bike, is this because the power vaule aint working, help, my bikes dieing what arer the possible solutions guys Sad
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
PostPosted: 17:03 - 05 Nov 2002    Post subject: Reply with quote
Have you checked the fuse?
It's displaying pretty similar symptons to when the fuse blew on my NSR.
If not it sounds like there might be a short circuit somewhere... well there may well be if the fuse has blown as well.
I wouldn't have thought it would cause damage to the bike, all the important bits are probably controlled mechanically.
JimboJ
Manc Pikey
PostPosted: 18:28 - 05 Nov 2002    Post subject: Reply with quote
retro i had the same problem! i dont know whether to give you solution. but hay i dont hold grudges Evil or Very Mad Twisted Evil Laughing it was as simple as the battery wasnt screwed on properly. i had the same thing with the rear lights. try tightening the + and - but not at the same time. let me know if that works!
[00:42] <NSR-Andy> which one's the missionary position
[00:42] <NSR-Andy> i've heard it's good
[9:42pm] <Shaun> you came first mike | <Shaun> yes gav, because I really want to fuck you
craigT19
Jolly Green Giant
PostPosted: 18:56 - 05 Nov 2002    Post subject: .... Reply with quote
well i had the same problem mate,
my nsr keeps feckin destroying batteries Sad
im on my THIRD battery in a year
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
Zimma
Wheelie Junkie
PostPosted: 19:28 - 05 Nov 2002    Post subject: Reply with quote
Luke, I'm not helping ya fix ya problems Razz
Retro stop fucking spamming, go home! Razz Twisted Evil
Very Happy
-Zimma
craigT19
Jolly Green Giant
PostPosted: 19:34 - 05 Nov 2002    Post subject: .... Reply with quote
lol @ zimma,
luke i wouldnt worry about it....the nsr just seems to have shite electrics Confused
PostPosted: 21:46 - 05 Nov 2002    Post subject: Reply with quote
Electrics are a black art, or more likely a bloody nightmare
Fuse first
Then I would check the earth at the ignition switch first. After that check all the other earths. If they problem is still there then time to search round with a multimeter
It could be that you have fried the regulator / rectifier unit. A well know Honda fault is dodgy ones of these (not as bad as Suzuki used to be)
retrofly
PostPosted: 22:58 - 05 Nov 2002    Post subject: Reply with quote
thanx guys and jim Razz, ok i'll do what u said, firstly where the fuse's and where's the earth for the egnition.
Oh yeah:-
Very Happy
Fuck u zim, just cause ure bikes shit Razz, and ure shuch a nob that u pulled a wheelie infront of cops Very Happy, tut tut, what a twat Razz
Very Happy
Dont mess with me BITCH Twisted Evil
Luke
Doddmaster
PostPosted: 23:28 - 05 Nov 2002    Post subject: Reply with quote
Like Keith says, make sure you check all the electrics before buying a new battery. If you do have a problem somewhere, it would just wreck another battery.
Craig - I think this is your problem too mate... no bike should get through batteries that quickly
PostPosted: 00:04 - 06 Nov 2002    Post subject: Reply with quote
If you have any worries about the battery, get a voltmeter and put it across the battery terminals. Should be about 12~13 volts with the ignition off. With the engine running this should go up to 14~15 volts as you rev it
PostPosted: 00:26 - 06 Nov 2002    Post subject: Reply with quote
The fuse is under the seat, in the little plastic 'tray' if I remember from Stehphen's bike.
retrofly
PostPosted: 14:44 - 06 Nov 2002    Post subject: Reply with quote
hi
ok it was tyhe fuse comming from the battery but the lights seem a bit dodgy and the starter motor is still not working, when i press the ignition it sounds like the engines moving VERY slowly and it makes sum kind of wirrring noise, is it a fucked starter motor, cause when i did work it would make sum wired noise's as i started the bike up? (looks for kickstart)
Luke
PostPosted: 14:53 - 06 Nov 2002    Post subject: Reply with quote
Have you ridden the bike (so the battery would get charged up again).. If the problem was intermitant it might have drained the battery with a short circuit before completly killing it.
Also whatever cased the problem is probably still there... so it'd be worth have a look at the wiring.
retrofly
PostPosted: 15:24 - 06 Nov 2002    Post subject: Reply with quote
will do G (kieths got a rival:P), when u say look at the wireing, do u mean the ones behind the lights, as that problem started when i got a new bulb fitted.
Il let u know how i get on,
Luke
Kris
PostPosted: 15:26 - 06 Nov 2002    Post subject: Reply with quote
Wrong bulb in the bike? Confused just a suggestion Razz
PostPosted: 15:37 - 06 Nov 2002    Post subject: Reply with quote
That'd be a good place to start... and possibly your indicators as I thought I remembered you saying they were dodgy.
As Kris said also check the Bulb.. apparantly the NSR is quite bad for killin batteries if you use too bright bulbs.
The last post was made 23 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 93.16 Kb
