| CaptainCrash1... |
 CaptainCrash1... L Plate Warrior
 Posted: 17:48 - 01 Oct 2019 Post subject: 2000 GPZ500S can't select 1st gear |
Hi, folks, new on here, so HELLO
Anyway, just bought a cheap GPZ500S to have a tinker with over the winter after been away from bikes for 18 years.
It runs lovely, although not ridden it yet as it has no MOT.
The problem I have is it won't select 1st gear. I've tried tightening the clutch cable, but that makes things worse. Pressing down on the selector just feels like it's already in first with nowhere else to go, no clicking or nothing. It will click up into 2nd and will drive the rear wheel, and will go up through all other gears. It is a bit vague through the gears though, certainly wouldn't want to ride it like that.
I'm going to take it apart on Friday, but any simple ideas that might solve it are greatly appreciated. I have read somewhere I might need to back the clutch off rather than tightening it, but there's no play left on cable, and clutch actually works fine. |
| doggone |
 doggone World Chat Champion
| stinkwheel |
 Posted: 18:36 - 01 Oct 2019 Post subject: |
Presumably this is with the engine running? Because it has a neutral-finder so it will be very reluctant to go into gear with the engine and bike stationary, one of the two needs to be moving.
There is a primary gear selector mechanism under a seperate cover located behind the front sprocket (it won't look like it until you remove the sprocket cover, the sprocket, the metal guard and clean all the crap off it.
It's effectively two hooks that grab a notch on the selector drum and rotate it one position round one way or the other when you change gear. Over time the points on the hook can wear rounded and slip off the drum instead of moving it.
It is an epic fiddle but you CAN get the whole lot out and back in again with the engine in the frame. I've done it twice. The entire splined shaft comes out, it's about 3" long with the mechanism attached. Relatively simple to file a point back on the selector notches and that's it fixed for another few tens of thousands of miles.
Be warned, my description is quite simplistic, there's a lot of small springy things in there, take digital photos as you dismantle it!
There are a few on ebay too for not very much money. It might be simpler to take the old one out and throw a replacement in rather than messing about with little pingy springs.
If you lean the bike over to the right a bit (steering over to full lock and lean the bar end against a wall), you can do it without draining the oil. This also makes it much easier to see what you're doing,
Could also be an issue with the gearbox itself but I've had one failing to engage gears twice now and both times it was that.
You may want to consider fitting a new shaft oil seal while you're in there. You will need to make or buy a new paper gasket for the cover.
https://www.ebay.co.uk/itm/Kawasaki-GPZ500S-Gear-Selector-Shaft-Mechinism-Changer-EX-500/133011637139?hash=item1ef81c8393:g:iK0AAOSwXY5ZQCn- ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| CaptainCrash1... |
| CaptainCrash1... |
The last post was made 7 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
