Need Help Substituting Polaris Brake Line
rebeltaz
PostPosted: 17:06 - 08 Oct 2019    Post subject: Need Help Substituting Polaris Brake Line Reply with quote
So... apparently, the main brake line on a 1997 Polaris Sportsman 500 - part # 1930760 - is no longer available. I've got this unit completely tore down in my shop and it needs all three front brake hoses, so I have to do something with it. I found a brake line that looks like I might could make it work, but I can't tell about the threads. The one I am looking at is part # 1910470 and it's listed as being for a Polaris Scrambler 500 4X4 and a Sportsman 6X6. This is the ONLY hose I've found that even LOOKS like it might work.
Does any one if the threads on Polaris brake lines are pretty much standard across the board?
Derek Tombrello
www.ShelbyCycle.com (for profit)
www.RobotsAndComputers.com (just for fun)
rebeltaz
PostPosted: 17:45 - 08 Oct 2019    Post subject: Reply with quote
Yeah, I'm sorry. I should have said that.
The main brake line is a straight angle banjo bolt down to a threaded fitting on a formed pipe that threads into a splitter block.
The two secondary lines (that go to the left and right slave cylinders) are both threaded fittings on formed pipes at both ends.
Derek Tombrello
Sister Sledge
PostPosted: 22:11 - 08 Oct 2019    Post subject: Reply with quote
Where are you? I'm sure that at least one shop on Westgate Road, Newcastle makes lines to suit.
CCM 404 DS
rebeltaz
PostPosted: 22:15 - 08 Oct 2019    Post subject: Reply with quote
If that is where I think it is when I did a search... I'm a bit further than that. I'm in Shelby Alabama, USA. Cool
Derek Tombrello
PostPosted: 22:35 - 08 Oct 2019    Post subject: Reply with quote
Polaris are big in the US, not so much in the UK so if it's not available over there, it isn't going to be here either.
Saying that though, there must be custom shops you can take the original too and ask them to match it up.
rebeltaz
PostPosted: 00:03 - 09 Oct 2019    Post subject: Reply with quote
I'm beginning to get the feeling that this forum is located in the UK... lol Smile I will see what I can find. Thanks guys.
Derek Tombrello
PostPosted: 11:30 - 09 Oct 2019    Post subject: Reply with quote
Nothing stopping you taking a custom made flexible line right to the bottom.
You probably want a car mechanic to make up ridgid brake lines. They do them on cars all the time and often just build them onto the car rather than buying in pre-made ones. Copper is probably better than steel.
Easy-X
PostPosted: 12:23 - 09 Oct 2019    Post subject: Reply with quote
I made some new rigid lines for a Passat once - binned the steel and went with copper, dead easy to work with. You just need a miniature pipe bender and a flaring tool. Plus you can bend copper by hand to get a perfect fit.
rebeltaz
PostPosted: 17:26 - 09 Oct 2019    Post subject: Reply with quote
One end is a flared fitting. So at least a part of that hose has to be rigid.
The hoses are only partially rigid. They are part metal, part rubber, so that they can move with the steering. I am going to take the hoses to my local NAPA (auto parts dealer) today. I think I remember seeing a sign that they can make hoses. Thanks.
Derek Tombrello
PostPosted: 18:23 - 09 Oct 2019    Post subject: Reply with quote
No it doesn't. You get screw-on fittings of all types for flexible hose. Male or female straight threads, concave or convex.
Looking at the picture earlier, one of these looks the part (obviously, I don't know your thread size):
https://www.ebay.co.uk/itm/283018075383
Only reason I can think of you'd HAVE to use a rigid brake hose is if there isn't clearance for a flexible one.
rebeltaz
PostPosted: 18:41 - 09 Oct 2019    Post subject: Reply with quote
Oh, ok... I appreciate that.
Derek Tombrello
The last post was made 7 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 85.51 Kb
