| SirFallalot |
 SirFallalot Trackday Trickster
 Posted: 08:28 - 11 Oct 2019 Post subject: 94 CB400SF oil quantity not specified |
Hey chaps, as I'm doing my yearly car oil change, and done 3k with the bike already I want to do it too including filter as idk when po did it.
Unfortunately, my manual does not specify much other than the viscosity for the given temperature range, no volume, no recommendation of manufacturer...It does however specify the amount of oil in the forks though
I've searched for the bike specs but didn't find any with an amount. Is it just gonna be the case of filling it up, turning it over a bit to fill the filter, then rechecking the dipstick and filling?
https://i.ibb.co/g9Kjdz0/Annotation-2019-10-11-081545.png
Also, what do you understand from this:
"1. Use the oil by the classification API -not
lower se (se, SF, SG)."
I was going to use either motul or castrol 10w-40  ____________________
Lexmoto Valiant 125; 94 CB400; 96 CB750F2; 81 CB750 (restoring, lol not gonna happen); 2001 ZX9R(It's about to go :c); 2012 R1200R; 2015 R1200RS |
| doggone |
 doggone World Chat Champion
| P.addy |
 P.addy Red Rocket
| SirFallalot |
| Riejufixing |
| Confusion |
 Confusion Scooby Slapper
 Posted: 13:57 - 11 Oct 2019 Post subject: Re: 94 CB400SF oil quantity not specified |
| TheWhiteBaron wrote: |
Unfortunately, my manual does not specify much other than the viscosity for the given temperature range.... |
That's all you really need to know. 10W-40 will be fine.
The CB400F (CB-1) manual says:
At draining: 2.9 litres
With filter: 3.1 litres
At dissassembly 3.5 litres
The Super Four should be around the same.
| Quote: | no recommendation of manufacturer... |
I'm surprised they missed the opportunity to recommend
Honda branded oil.
| Quote: | I've searched for the bike specs but didn't find any with an amount. Is it just gonna be the case of filling it up, turning it over a bit to fill the filter, then rechecking the dipstick and filling? |
Yes, it is as simple as that. Be glad the SF has a centre stand,
so you won't need an assistant.
| Quote: | Also, what do you understand from this:
lower se (se, SF, SG)." |
Those are obsolete API specs. It is safe to use oil with newer
API specs provided you avoid 'energy conserving' types that
might not be compatible with the wet clutch in your Honda.
| Quote: | I was going to use either motul or castrol 10w-40 |
Flash bastard with your 'proper' bike oil. I use regular 10W-40
semi-synthetic from the local auto factors, currently Valvoline All-Climate.
Half the price of similar spec bike oil. ____________________ Bandit 650SA, ZZ-R1100 |
| Polarbear |
 Polarbear Super Spammer
The last post was made 7 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
