Ignition advancer.
Kawasaki Jimbo
PostPosted: 19:55 - 12 Oct 2019    Post subject: Ignition advancer. Reply with quote
Someone with a ZX7R has written in to Practical Sportsbikes (October) saying they have a DynoJet Stage 1 tune (like my 6R) and a 4 degree ignition advancer. Wassat? And should I get one?
stevo as b4
PostPosted: 00:09 - 13 Oct 2019    Post subject: Reply with quote
Yes you should if you have a skimmed and flowed cylinder head, and you run on super unleaded or race fuel.
In essence it does nothing for peak power on a std engine, just moves the torque delivery around favouring low down response. If you run high octane fuel then advancing the part throttle timing might get you something worth having. But an ignition advancer rotor is old school and vastly inferior to a fully programmable ignition. The thing on a four stroke bike is that unless you've been into the engine for serious tuning, then a tunable ignition map won't really make much difference to performance on a std bike. Your better off just messing with fueling for exhaust and intake modifications IMO.
Easy-X
PostPosted: 12:00 - 13 Oct 2019    Post subject: Reply with quote
Purely for educational purposes, what does advancing the timing do, as a general concept?
Riejufixing
PostPosted: 12:20 - 13 Oct 2019    Post subject: Reply with quote
It makes it go bang earlier.
Bhud
PostPosted: 12:50 - 13 Oct 2019    Post subject: Reply with quote
Pinging is the main risk involved, and it can be exacerbated by hotspots in the cylinder head and on the piston crowns. I did it to my XJ600 after I'd had the head off and removed all the carbon deposits, and it made a noticeable difference. It's a common mod for those bikes. However, they aren't bikes that people worry about unduly...
weasley
PostPosted: 14:01 - 13 Oct 2019    Post subject: Reply with quote
If by “earlier” you meant “later”, then spot on.
The spark normally goes off some time before top-dead-centre (TDC), meaning that the the combustion starts as the piston is still moving up. This means that the first little bit of effort put out by the combustion is actually working against the engine, but eventually the piston moves past TDC and the bulk of the combustion happens during the down-stroke.
If you have a higher compression and use more knock-resistant fuel (higher RON) you can get away with advancing the spark so it happens later, meaning more of the ‘bang’ goes into pushing the piston down rather than slowing it down.
Riejufixing
PostPosted: 15:36 - 13 Oct 2019    Post subject: Reply with quote
weasley wrote:
If by “earlier” you meant “later”, then spot on ... If you have a higher compression and use more knock-resistant fuel (higher RON) you can get away with advancing the spark so it happens later
Eh? The spark comes further before TDC. Retarding the ignition means it fires later.
Easy-X
PostPosted: 18:17 - 13 Oct 2019    Post subject: Reply with quote
Um, so firing at TDC would only be "okay" if the flame front moves at high speed, e.g. Hydrogen. For petrol it takes a little longer so you spark a touch earlier so the point of highest pressure, i.e. the flame front has got to the sides of the cylinder, is just on the downstroke. Have I got that right?
Advancing the timing is sparking earlier and retarding the timing is later?
And where does knock and high octane fuel come into the equation?
misscrabstick
PostPosted: 18:47 - 13 Oct 2019    Post subject: Reply with quote
Weasley said
"If by “earlier” you meant “later”, then spot on."
No, advanced is making the spark happen further before TDC, retarding it is nearer to or after TDC.
Advance means occurring earlier, and retarding occurring later.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:58 - 13 Oct 2019    Post subject: Reply with quote
Actually, advancing the ignition means the spark happens earlier.
Most ignitions have a method of advancing the ignition as the engine revs incre|se because the bang needs time to propgate. Typically, the spark actually happens before the piston is at tdc. As the engine speed increases the spark has to be earlier as that the propogation of the compustion takes the same length of time . if it wasn't earlier, the bang would happen progressivly after tdc as revs increase, costing power.
most rev limiters actually work by retarding the igntion, stopping the engine from overrevving. If they just cut the spark entirely , fuel mixture would just go down the exhaust and go bang really loudly every time you hit the rev limiter.
Triumph Sprint ST 1050
Riejufixing
PostPosted: 22:13 - 13 Oct 2019    Post subject: Reply with quote
I bet he knows that really, it's just the drink confusing things.
Nice to see you both, by the way.
Riejufixing
PostPosted: 22:15 - 13 Oct 2019    Post subject: Reply with quote
....or when you let go of the kill switch, or switch the ignition back on, and a bloody great flame shoots out too. Oh! Is that the time, sorry, must run.... Smile
weasley
PostPosted: 09:16 - 14 Oct 2019    Post subject: Reply with quote
Yep, ignore me, got it right in my head but wrong out loud. As you were.
The last post was made 6 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 80.09 Kb
