Kawasaki 305 Oil Pump Drive Sprocket options?
Alpha9five
PostPosted: 01:58 - 10 Oct 2019    Post subject: Kawasaki 305 Oil Pump Drive Sprocket options? Reply with quote
Hi everyone. Most that know the Kawasaki 305 motors know they have 2 major flaws, the oil pickup and the oil pump drive sprocket, along with the rest. Is there any upgrade options for the oil pump drive sprocket? Or for anything in this motor at all. That is probably the most concerning bit for me if the teeth go on one of those and screws the rest of the motor.
PostPosted: 09:27 - 10 Oct 2019    Post subject: Reply with quote
The teeth won't strip if the pickup isn't blocked. Make sure the pickup doesn't block by removing the oil pump and cleaning the strainer once a year.
It will then be free to kill itself in some other way. My wife has killed three of those engines, none of them due to oil starvation.
I'd say the major flaw is that it's a 250cc motor that has been bored out well beyond its original design limits in an attempt to make it faster than a superdream. A shame, because it's otherwise a lovely wee bike to ride.
The best solution would be to sell it and buy a 400 superdream instead.
Alpha9five
PostPosted: 16:07 - 10 Oct 2019    Post subject: Reply with quote
Cheers for the advice stinkwheel. I have heard the horror stories with these motors. As many as 3? All the same failed parts or all 3 different?
stevo as b4
PostPosted: 00:23 - 13 Oct 2019    Post subject: Reply with quote
36bhp and 10000rpm isn't bad for a 305cc air cooled two valve twin, so I'd say they would be more fun than a big superdream 400? I think they clocked 102-103mph in period road tests, so I'd be surprised if the CB400N is much faster or twice as reliable even?
All these little four stroke twins seem fragile, probably due to poor maintenance or neglect without frequent enough oil and filter changes, a big old Z1000 or similar would shrug off this neglect for decades, but a 250cc 30bhp twin that's ridden to the limit all the time won't. You don't hear about XS250's or GSX250's being unkillable or capable of serious abuse either, because they aren't.
Does the GPZ have an external oil cooler? If not and I really wanted to thrash one I'd consider plumbing one in, as it'd add oil capacity as well as keeping the hard worked oil cooler.
redeem ouzzer
PostPosted: 00:25 - 13 Oct 2019    Post subject: Reply with quote
Better off with an LC..
Be a REAL MAN!
stevo as b4
PostPosted: 00:36 - 13 Oct 2019    Post subject: Reply with quote
Indeed! Standard 250LC performance without the acceleration at best, and without the option of an easy 20% power increase with a simple tune and set of pipes.
But someone out there has to love these little miniature wannabe GPZ's, GSX's and Euro stye Honda's. In a perverted way it must be quite satisfying for some to thrash these little bikes up to 5 figure engine speeds and on a good day with a strong tailwind see the speedo pass the 90mph mark. Even if an AR125 or TZR125 would do it much more convincingly.
PostPosted: 01:02 - 13 Oct 2019    Post subject: Reply with quote
Yeah but who can afford to buy a LC nowadays?
stevo as b4
PostPosted: 01:11 - 13 Oct 2019    Post subject: Reply with quote
I might have known someone who once passed on buying a 500LC that had a knackered gearbox which would jump out of 2nd and 3rd gear, and was up for £1400ono. Doh!
PostPosted: 00:09 - 15 Oct 2019    Post subject: Reply with quote
However the 250 scorpion from which the 305 was derived was a fine wee bike. Just not as fast as a superdream.
The fact is that while a GPz305 CAN do 110mph, it under no circumstances SHOULD do 110mph because all the engine internals weld themselves together after a few miles.
Two heat seizures and one big-end failure (oil pump drive intact in all three cases).
If you want a 250-ish classic 4t, I'd go for a CB250RS.
BusterGonads
PostPosted: 11:34 - 24 Oct 2019    Post subject: Reply with quote
I had one of them thirty years ago. It was a great little bike, but I wouldn't say it was that fast. I took my then ten year old son from Newcastle to Turin on it - loaded up with camping gear. We had a great time riding down the French N roads to Grenoble, and over the Alps to Briancon and Turin. I had intended to go further into Italy, but we had a near accident in heavy rain when the rear wheel lost traction, then grabbed and nearly threw us off. I got conscience trouble thinking about how I nearly had my son on the deck and went back to Provence and then up the AutoRoute to Paris and back home to Newcastle. I wish I'd kept that bike as a museum piece after but I sold it. It did 2750 miles on that trip with just a couple of oil changes and chain adjustments the whole way.
2023 Royal Enfield Classic 350; 2000 Honda CG125; 1997 Honda Nighthawk CB250
The last post was made 6 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 65.88 Kb
