Let's see...
Paper gaskets.
Spit first (lube)
52%
 52%  [ 10 ]
Dry
31%
 31%  [ 6 ]
What's that Slav talking about?
15%
 15%  [ 3 ]
Total Votes : 19
RhynoCZ
PostPosted: 00:04 - 13 Oct 2019    Post subject: Let's see... Reply with quote
Just for the fun of it... Thinking
mentalboy
PostPosted: 03:35 - 13 Oct 2019    Post subject: Reply with quote
Where's the 'grease' option?
Make mine a Corona.
Sister Sledge
PostPosted: 06:44 - 13 Oct 2019    Post subject: Reply with quote
Top or bottom?
CCM 404 DS
PostPosted: 10:44 - 13 Oct 2019    Post subject: Reply with quote
Grease in most cases although some form of gasket sealer in some situations.
Never dry.
Triumph Trophy Launch Edition
Islander
PostPosted: 10:50 - 13 Oct 2019    Post subject: Reply with quote
A light smear of grease. Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 13:15 - 13 Oct 2019    Post subject: Reply with quote
I always go in dry.
Triumph Sprint ST 1050
ThatDippyTwat
PostPosted: 14:57 - 13 Oct 2019    Post subject: Reply with quote
I put a smear of 10W40 on most paper gaskets I make. Maybe some Hylomar around the stator bung, they're usually chewed up on older bikes. Only leaks I've had using it are blonde moments on my part, not gasket failure.
A couple of local kids were blown away me making my own with gasket paper and a rounded screwdriver handle, and a very light tap or two with a small ballpeen. They work on their own pitbikes etc, so they're not strangers to a spanner, but gasket paper just wasn't a thing to them. You buy one and wait for it to show up in the post.
edit - Typos, phone, big hands, you know the drill.
Riejufixing
PostPosted: 15:31 - 13 Oct 2019    Post subject: Reply with quote
ThatDippyTwat wrote:
making by own with gasket paper and a rounded screwdriver handle, and a very light tap or two with a small ballpeen
I'd bet that most people have never heard of that method.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:41 - 13 Oct 2019    Post subject: Reply with quote
It's a recognised technique.
PostPosted: 16:25 - 13 Oct 2019    Post subject: Reply with quote
Standard practice in engineering circles where you use gasket sheet rather than pre cut gaskets although in most cases I just use the ball pein hammer. It's the only way to make gaskets for stuff like the pump casing shown below. Pre cut cost an absolute fortune from the pump manufacturer, 100's of dollars.
https://i.postimg.cc/DfW5RwdM/IMAG0006.jpg
Riejufixing
PostPosted: 16:45 - 13 Oct 2019    Post subject: Reply with quote
I'd bet that most people have never heard of that method. Most people don't even know about BCF.
WD Forte
PostPosted: 18:23 - 13 Oct 2019    Post subject: Reply with quote
I made many with a ball pein hammer as an apprentice
but that was on steel.
On bikes which are mostly alloy I use rawlplugs or tapered screwdriver blade to lock the gasket material in position
then a xacto/scalpel type thing in a sawing motion around the profile
I've also scanned a few sub A4 sized assemblies and used the machine to cut them
A light greasing on assembly
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 18:35 - 13 Oct 2019    Post subject: Reply with quote
Most people couldn't find their arses if their thumb was in their anus either.
ThatDippyTwat
PostPosted: 19:30 - 13 Oct 2019    Post subject: Reply with quote
As said, in engineering it's absolutely standard. Old-school, yeah, but it's worked for, what, centuries? Possibly.
Ballpein is only used for smaller diameter holes (dowels, bolts etc), and only enough to outline so I can cut the gasket with a scalpel. A round plastic screwdriver handle I have works a treat for anything else.
ThunderGuts
PostPosted: 08:58 - 15 Oct 2019    Post subject: Reply with quote
Genuinely interested in this concept (not that I've got any immediate application for it, it's just interesting); are you running the handle around the edges of the surface to leave an impression in the paper to then cut to?
TG.
PostPosted: 10:20 - 15 Oct 2019    Post subject: Reply with quote
You can do that, or just use the hammer - GENTLY Laughing
https://www.youtube.com/watch?v=U-YJo99OCu8
RhynoCZ
PostPosted: 10:36 - 15 Oct 2019    Post subject: Reply with quote
Like so, ... https://youtu.be/lAS8mpXVLOg?t=160 Smile
The lad in the video above is too harsh and uses the wrong kind of hammer.
Riejufixing
PostPosted: 12:50 - 15 Oct 2019    Post subject: Reply with quote
Ow! OW! Crying or Very sad
ThatDippyTwat
PostPosted: 19:43 - 15 Oct 2019    Post subject: Reply with quote
You can hammer through the paper, which is fine with steel castings, or thick Alu ones. I do it in work all the time.
I find bike stuff is a bit dainty, so as you rightly surmised, I get an impression and cut it with a scalpel.
The last post was made 6 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.09 - MySQL Queries: 15 - Page Size: 104.47 Kb
