Starting Issue
Martin Higgins
PostPosted: 15:54 - 13 Oct 2019    Post subject: Starting Issue Reply with quote
Hi all,
I'm having a problem starting my bike. I did my valve clearances this morning and then took the bike a run to check it ran OK (which it did). I then proceeded to put the side fairings back on and went to start the bike up, when I tried the whole bike died before the starter tried to turn, no lights etc.
After checking I noticed the positive terminal on the battery was loose, tightened it up and tried again. Now the bike lights up etc and tries to turn over but doesn't quite fire up. The starter is clicking but the bike just won't start. Any advice?
I'm new to motorbikes and still learning the basics and maintenance so any help will be greatly appreciated.
dynax
PostPosted: 15:58 - 13 Oct 2019    Post subject: Reply with quote
Try charging up the battery Thumbs Up
Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber
Martin Higgins
PostPosted: 16:37 - 13 Oct 2019    Post subject: Reply with quote
Hi, battery is sitting at 12.4v standby and 11.3v when trying to turn over.
PostPosted: 16:41 - 13 Oct 2019    Post subject: Reply with quote
That's bordering on 'not very good' as a standing voltage.
Recharge it and try again. If it falls back to a standing voltage of 12.4 or less it's time to think about replacement.
Modern bikes are really power sensitive and a flat/low battery can cause other issues that don't seem related.
Sort your battery first and take it from there.
Try jumping from a car battery and see if it goes straight away.
Triumph Trophy Launch Edition
Martin Higgins
PostPosted: 16:52 - 13 Oct 2019    Post subject: Reply with quote
I've got a charger coming tomorrow so will try again then and see how that goes. Thanks for the help 🙂
Martin Higgins
PostPosted: 20:58 - 14 Oct 2019    Post subject: Reply with quote
So I charged the battery up, it was a little on the low side but still within range to start the bike. Still no joy on starting. Checked the fuses and all seem OK.
Moved on to fuel system as the enfine is turning over with the starter but is just refusing to start. Cracked open the fuel pump to see if fuel was there (which it was) so tightened back up. I then pulled the fuel line (pump) side out and reattached, and then the bike fired up first time.
Tightened the fuel tank back down and put the seat back on to take it a quick test ride and it wouldn't start again 😭
At my wits end now, guessing the fuel system isn't doing its job but it just doesn't make sense to me.
doggone
PostPosted: 21:24 - 14 Oct 2019    Post subject: Reply with quote
Sounds like a fuel line kinking when you put the tank on firmly?
Double check your battery terminals are clean and tightened up properly.
Are you now getting reasonably fast turning over but it won't fire?
Martin Higgins
PostPosted: 21:34 - 14 Oct 2019    Post subject: Reply with quote
The fuel supply from tank looks fine, not kinked, it was the firmer plastic one that I removed and refit.
Bike is turning over fine, nice and fast. I quickly checked the spark plug and it was wet with fuel, dried it off and tested it, didn't seem to be sparking, touching off a head bolt. Couldn't remember if my clutch needs to be in though to allow ignition so I'll need to check again tomorrow to know for sure.
The last post was made 6 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 55.66 Kb
