CB500 carbs leaking fuel from breather
Kermitsbog
PostPosted: 12:20 - 17 Oct 2019    Post subject: CB500 carbs leaking fuel from breather Reply with quote
Hello again,
2000 Honda CB500 - rebuilt the carbs with new float needles etc. Original floats, they are plastic but float in water fine. They are also pre-set so their height can't be adjusted.
Installed onto the bike. Wanted to test it runs ok before tank goes back on etc so rigged up a fuel can on the seat, got a syphon going and then connected the pipe to the fuel filter/line.
Shortly after fuel began leaking out of the carb breather so I clamped off the pipe.
Engine starts and runs ok but as soon as I undo the clamp it slowly begins to leak from the breather.
I've read it might be the floats and/or float valves.
However I know the floats are delicate little things so wondered if how I've rigged this up us creating too much head pressure, pushing fuel past the float valves? Is that even possible or have I just made that up.
I'm trying to avoid taking the carbs off again if I can help it since they are a bastard to get on and off Laughing
PostPosted: 12:58 - 17 Oct 2019    Post subject: Reply with quote
Could be stuck or leaking needle valves.
Try tapping the carbs with a bit of wood, that can settle stuck ones down.
They could be leaking though. They could have been leaking before you stripped it but the vacuum fuel tap prevents them overflowing when the engine is off. It's a common issue on Japanese bikes.
If they keep leaking, I'd have a close look at the needle valve seats with a magnifying glass.
Incidentally, a CB500 is one of the easiest sets of carbs I've ever worked on. You do know the whole airbox pivots back off them complete with rubbers? As I recall you need to remove the battery and undo one bolt, loosen the airbox rubber clamps and pivot the whole airbox backwards off the carbs. Hold it there with a bungee.
You don't need to remove them entirely to remove the float/needle valves, dismount them from the rubbers and turn them upside down and you'll be able to remove the float bowl without disturbing the cables.
Kermitsbog
PostPosted: 13:30 - 17 Oct 2019    Post subject: Reply with quote
Ah thanks that's interesting, I'll give that a go.
I can't say I looked in the needle valve holes, just blasted them with carb cleaner, maybe they are a little dirty still.
It's not the getting them out that's the pain so much, it's pushing them into the rubber inlet seals after. The clamps were loosened right off but I had to wiggle them and use a lot of force to get them back on. Maybe I should warm them up with some hot water or something?
Kermitsbog
PostPosted: 18:07 - 17 Oct 2019    Post subject: Reply with quote
I bought a float bowl gasket set off eBay for the carbs that came with 2 float needles, £18 each so not the cheapest.
The bikes only done 16k miles so I would hope they are not too worn after that.
Sounds like I need to have a good look at them, good job I kept the original ones. I've got a micrometer so I'll compare them.
PostPosted: 12:21 - 18 Oct 2019    Post subject: Reply with quote
I heat up carb rubbers with a hairdrier. A smear of red rubber grease round the lip of the rubber makes life much easier too.
Kermitsbog
PostPosted: 16:52 - 18 Oct 2019    Post subject: Reply with quote
mpd72 wrote:
I bought some from a well known parts place, fitted them and couldn't stop the carbs from pissing fuel. I took them out and compared them to the existing ones. There was a couple of mm difference in size, enough to stop them from sealing. I photo'd them and they just refunded me.
Pretty much the same issue here, the new ones didn't seal. I've swapped them over with the old ones and all is good!
Seems that with taking the carbs off and on a few times now it's getting easier, they pretty much popped back on this morning with no grief.
The last post was made 6 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.97 - MySQL Queries: 13 - Page Size: 58.62 Kb
