Bike dies all of a sudden.
Farmingstock
PostPosted: 14:40 - 20 Oct 2019    Post subject: Bike dies all of a sudden. Reply with quote
I have an LT50 quad copy for my son.
It was a cheap none runner, the wires were connected wrong and after sorting them I got it running.
However
The bike won’t start on the first pull, it’s more like 5-10 pulls to get it started, any choke on and the bike won’t start, put the choke on whilst the bike is running and it will die.
When it’s started and riding along it’ll bog down and cut out within seconds, it may run for a little while but then just bogs down again.
I have bought a new carb which has made no difference and adjustments to air screw makes no change, it almost has to be completely shut to make it set off without bogging and cutting out.
Any ideas?? The wiring is fine now, I check the over flow when it cuts out to make sure fuel in bowl and there always is, Im pretty stumped!!
PostPosted: 14:54 - 20 Oct 2019    Post subject: Reply with quote
Checked the valves?
Farmingstock
PostPosted: 14:56 - 20 Oct 2019    Post subject: Reply with quote
It doesn’t have any as such, it’s a cheap Chinese 2stroke engine and there is only an inlet pipe, no reed valves.
Copycat73
PostPosted: 17:01 - 20 Oct 2019    Post subject: Reply with quote
have you considered that the choke operated in the opposite direction.. ie. what you think is on... is actually off and vice versa ... ?
caveat emptor
bugeye_bob
PostPosted: 17:06 - 20 Oct 2019    Post subject: Reply with quote
When it does die is the plug wet ? and is there a spark?
Farmingstock
PostPosted: 20:35 - 20 Oct 2019    Post subject: Reply with quote
Spark yes as far as I know as it will start again straight away then do the same thing again, not sure about wet plug though!
Choke definitely right way as I had the last carb in bits to check
jaffa90
PostPosted: 21:37 - 20 Oct 2019    Post subject: Reply with quote
As said, give it some throttle during dying and see if the plug is wet or dry.
Also the exhaust may be part blocked!
Farmingstock
PostPosted: 21:57 - 20 Oct 2019    Post subject: Reply with quote
Will check tomorrow, what happens in each scinario also could it be anything to do with the coil/fuel mixture? 50/1
jaffa90
PostPosted: 22:31 - 20 Oct 2019    Post subject: Reply with quote
""""I have bought a new carb which has made no difference and adjustments to air screw makes no change, it almost has to be completely shut to make it set off without bogging and cutting out.""""
Has it any unwanted air going in somewhere and does the engine have any leaks or weeping?
steve the grease
PostPosted: 22:57 - 20 Oct 2019    Post subject: Reply with quote
Over the years I have learnt with 2 strokes , always , always , always stick a new plug in.
Farmingstock
PostPosted: 18:45 - 21 Oct 2019    Post subject: Reply with quote
Ordered yet another new carb today and everything seems fine now, possibly two dodgy carbs but seems to run much better now!
Hopefully problem solved.
jaffa90
PostPosted: 20:57 - 21 Oct 2019    Post subject: Reply with quote
I`ve had a faulty chinky carb for a lawnmower, the fuel level was to low preventing high revs.
Farmingstock
PostPosted: 23:09 - 21 Oct 2019    Post subject: Reply with quote
I did think that there was an issue with the float, meaning it would empty the bowl and make the engine bog, but everytime I checked the bowl it was leaking fuel!!
Anyway fingers crossed
The last post was made 6 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 71.32 Kb
