Restricting the fork travel on a 2008 R1 forks
Mark Serj
PostPosted: 15:19 - 16 Oct 2019    Post subject: Restricting the fork travel on a 2008 R1 forks Reply with quote
Gents,
I am fitting a pair of these to my XV750 Virago café racer project but need to restrict the fork travel. Has anyone done this please?
Regards
Mark
Mark Serj
Easy-X
PostPosted: 17:35 - 16 Oct 2019    Post subject: Re: Restricting the fork travel on a 2008 R1 forks Reply with quote
If we say c*** r**** three times do you think we can get Teflon Mike to appear? Smile
These the factory forks or something new?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:38 - 16 Oct 2019    Post subject: Re: Restricting the fork travel on a 2008 R1 forks Reply with quote
Mark Serj wrote:
Gents,
Regards
Mark
Yet another perfectly serviceable bike ruined.
Triumph Sprint ST 1050
PostPosted: 19:39 - 16 Oct 2019    Post subject: Reply with quote
What exactly do you want to do?
Reduce the overall length of the fork so the wheel is closer to the bottom yoke or keep the fork the same overall length but only allow it to move up and down by less distance?
The aren't overly endowed with fork travel at the best of times, gooogle says 120mm.
In either case, it would be tricky.
You could fit a cartridge with a shorter rod and shorter springs/spacers ( modified or off another bike) which would make the overall fork length shorter but retain the usual amount of travel. That'll work to a point providing the stanchion doesn't bottom out.
I can't think of a way to physically restrict the overall travel. Maybe fitting stiffer springs to reduce how much they compress under load, but that will cock up all the fork action.
The actual physical travel is determined by the travel of the piston in the cartridge. That would not be simple to alter.
Equally. Less than 120mm of fork travel? Rather you than me. An R1 seems a tad on the extreme minimum end in that respect anyway. I doubt you'll find a cartridge that has much less that would fit.
Shittier forks with a damper rod assembly would be easier to fuck-with.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:49 - 16 Oct 2019    Post subject: Reply with quote
It does seem the height of perversity to introduce extreme race derived forks to a cruiser frame to make said cafe abortion.
I really can't see what eventual outcome you are aiming for, aside from the inevitable wrapping it round a lamppost as it tries to simultaneously over and under steer off the road.
Your best bet is to pray that the cruiser steering geometry is too slow to allow it to readily speed wobble.
A100man
PostPosted: 23:28 - 16 Oct 2019    Post subject: Reply with quote
Dear Mark
You might find more like minded souls here..
https://thebikeshed.cc
Mark Serj
PostPosted: 12:18 - 17 Oct 2019    Post subject: Restricting the fork travel on a 2008 R1 forks Reply with quote
Thanks for replies guys.
I acquired the bike as a chopped about blacked out dog that will be all the better for the modifications I am planning, no matter how they turn out, and at least it will be back on the road.
A well respected US custom bike builder fitted R1 forks to a 750 Virago and apparently it handles very well. However I can see from the pics that the front wheel looks like it will touch the exhaust so I enquired about this and he replied saying the travel has to be restricted. I’m not too keen on that idea but while I am waiting for his reply as to how he has achieved this, I thought I would ask about in case there are others who have done this and just fact find / learn whats out there - all part of the whole forum ethos…..well, …….in most cases anyway. The other options I am considering are:
1. Machining up some new yokes with an increased stem to fork offset (say about 25mm) to aid the clearance issue
2. Making a new top yoke which is deeper to allow the forks to raise the ride height at the front by about an inch, again to aid the clearance issue.
3. Possible combo of the above
4. When I fabricate the exhaust I will make the initial bend as favourable as possible and potentially out to the side, or even slightly raised in its direction for same reason.
Easy-X, sorry not sure I understand your question
Stinkwheel – thanks for the comprehensive reply – I hope the above points give you a better understanding of my project.
Best Regards
Mark Serj
PostPosted: 13:06 - 17 Oct 2019    Post subject: Reply with quote
I would aim to maintain the same rake angle and wheelbase as originally fitted as far as possible to avoid handling issues. I'd imagine this would mean raking an R1 fork out considerably (I'm guessing they are considerably shorter than standard).
A virago is an odd choice for a café racer mind. They are dog slow.
Mark Serj
PostPosted: 09:11 - 21 Oct 2019    Post subject: Restricting the fork travel on a 2008 R1 forks Reply with quote
I won’t be able to keep the same rake angle or wheelbase stinkwheel as the forks are a lot shorter. I wouldn’t want to do that anyway mate as that would maintain the Viragos steering characteristics which wouldn’t suit a café racer type bike very well.
Mark Serj
PostPosted: 18:47 - 21 Oct 2019    Post subject: Re: Restricting the fork travel on a 2008 R1 forks Reply with quote
It will handle like a pig. Try dropping the current forks through the yokes so they are the same length as the ones you intend to fit. Then cautiously try riding it. It will tend to fall over into corners and feel very twitchy. It might start tank slapping.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:53 - 21 Oct 2019    Post subject: Reply with quote
Make sure you get someone to film you when you come to a corner for the first time.
ThatDippyTwat
PostPosted: 19:04 - 21 Oct 2019    Post subject: Reply with quote
I'd rather have a black ratted, doggy looking bike that can actually, I dunno... take a fucking corner.
Go fuck up a 125 or something, and hack the subframe off that, stick a shitty, brown, uncomfortable seat on it and flog it to some Shoreditch wanker with a flannel shirt for £5K.
R1 forks on a fucking Virago... jesus wept.
Mark Serj
PostPosted: 15:11 - 22 Oct 2019    Post subject: Re: Restricting the fork travel on a 2008 R1 forks Reply with quote
Good suggestion mate, I would if I could but I bought it as a box of bits so can't try that. I can see people are getting upset with this post so I'll sign off and let you know how I get on when its finished.
Cheers,
Mark
Mark Serj
Easy-X
PostPosted: 16:02 - 22 Oct 2019    Post subject: Reply with quote
I'm not going to condone what you're trying to do but I'm watching these fellas fuck up a perfectly good BSA do a hardtail conversion. This episode they dick with the forks:
https://www.youtube.com/watch?v=BHcf7JRGB3Q
Mark Serj
PostPosted: 16:11 - 22 Oct 2019    Post subject: Reply with quote
I'll have a look, thanks
Mark Serj
PostPosted: 17:01 - 22 Oct 2019    Post subject: Re: Restricting the fork travel on a 2008 R1 forks Reply with quote
No, you have to keep us updated as it progresses. Razz
Did you hear back from him?
Mark Serj
PostPosted: 07:05 - 23 Oct 2019    Post subject: Re: Restricting the fork travel on a 2008 R1 forks Reply with quote
Only that they need restricting on travel, not how he achieved this, but I may get a response sometime as he is a busy bloke.
Mark Serj
Nobby the Bastard
Harley Gaydar
PostPosted: 07:40 - 23 Oct 2019    Post subject: Reply with quote
He probably tried to ride it and is still in a & e waiting for them to crowbar the seat out of his arse where he puckered up in fright.
The last post was made 6 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 102.02 Kb
