1981 GS550 Wont rev above 6-7k unless running out of fuel
octusis
PostPosted: 17:54 - 24 Oct 2019    Post subject: 1981 GS550 Wont rev above 6-7k unless running out of fuel Reply with quote
I've looked all over the place and can't find anything on it. I've adjusted the floats to what I believe is factory spec. The bike seems to rev fine in neutral or just off-load in general but as soon as its under any kind of load it just falls on its face unless its running out of gas by shutting off the petcock.
I'm stumped at this point if anyone has any ideas on what it could be I would really appreciate it Very Happy
Easy-X
PostPosted: 21:58 - 24 Oct 2019    Post subject: Reply with quote
Hmm, not getting max airflow at full throttle perhaps? (Restricting the fuel would lean it out to balance this.)
Worth checking the air filter and exhaust for blockages.
jaffa90
PostPosted: 22:35 - 24 Oct 2019    Post subject: Reply with quote
Sounds like a rich mixture and improves with less fuel (lowering the fuel level in the carbs).
Are the main jets standard?
The spark plugs colours will tell a tale.
jaffa90
PostPosted: 23:25 - 24 Oct 2019    Post subject: Reply with quote
The O.P. says it is ok for a mo after turning the fuel tap off.
So how can it be the air intake change?
chickenstrip
PostPosted: 23:44 - 24 Oct 2019    Post subject: Reply with quote
1981 bike? I wonder what condition all the carb seals and o rings are in?
jaffa90
PostPosted: 00:33 - 25 Oct 2019    Post subject: Reply with quote
Another thought, does it have a vacuum operated fuel tap?
If so is there any fuel in that pipe going into the intake manifold?
octusis
PostPosted: 05:20 - 25 Oct 2019    Post subject: Reply with quote
It seems to be getting solid airflow because the plugs are rather chalky. 2 seem to be chalky while the other 2 seem to be an alright color
octusis
PostPosted: 05:21 - 25 Oct 2019    Post subject: Reply with quote
I believe the main jets are standard and as for the fuel level in the carbs i set them at 22.4 which is factory (or so i thought) Do you know from what point to what point they are to be measured? these carbs have stepped floats.
octusis
PostPosted: 05:23 - 25 Oct 2019    Post subject: Reply with quote
mpd72 wrote:
I’m thinking like Easy-X. If it’s over fuelling, it could be due to “under airing”. What’s the air filter like?
I've got pods on it and theyre brand new, never ran it with the stock box because i dont have it so i'm not sure, my application cant use the stock box.
octusis
I've went through some of them that i already seen were cracked and old, as for the floats and things they seem to be sealed alright
octusis
PostPosted: 05:24 - 25 Oct 2019    Post subject: Reply with quote
I've got it gravity fed at the moment.
Damon
PostPosted: 09:48 - 25 Oct 2019    Post subject: Reply with quote
Have you tried lowering the float level a tad?
octusis
PostPosted: 00:38 - 27 Oct 2019    Post subject: Reply with quote
I've tried all different levels of lowering them, could it be that they are worn?
jaffa90
PostPosted: 00:59 - 27 Oct 2019    Post subject: Reply with quote
What happens when you leave the fuel tap on when not using the bike?
Robby
Dirty Old Man
PostPosted: 16:49 - 27 Oct 2019    Post subject: Reply with quote
Got confused and left the choke on?
octusis
PostPosted: 17:00 - 27 Oct 2019    Post subject: Reply with quote
One of the carbs will sometimes leak, it doesnt seem like it always does though and it's only one of them
octusis
It needs choke to start and I always shut it off and it seems to return okay so I dont think thats it..
jaffa90
PostPosted: 18:28 - 27 Oct 2019    Post subject: Reply with quote
That is the problem.
temeluchus
PostPosted: 20:25 - 27 Oct 2019    Post subject: Reply with quote
You'll need to at least replace all the seals and float needles/valves in the carbs.
Don't try and cheap out, it might end up with the bike on fire.
octusis
PostPosted: 05:14 - 28 Oct 2019    Post subject: Reply with quote
Do you know how to remove the jet where the float needle sits in? I've tried to remove it in one of them by minimal force to not damage it and I couldn't seem to get it to dislodge, do they screw out or pop out?
octusis
PostPosted: 05:15 - 28 Oct 2019    Post subject: Reply with quote
So the float needles and seats should be replaced in all of the carbs?
chickenstrip
PostPosted: 18:03 - 28 Oct 2019    Post subject: Reply with quote
If this is anything more than a hobby bike, I'd be thinking about getting shot of it for something else tbh. Getting a bit too long in the tooth, and I doubt parts are easy to come by if you need anything other than wear-and-tear.
If it's a hobby bike, I'd be looking at replacing anything in the carbs I could get new replacements for. What state is the inside of the fuel tank? If it's feeding crap into the carbs, it might cause fuel leaks/flooding/god knows what. Likewise with fuel lines. It doesn't take much.
octusis
PostPosted: 00:33 - 30 Oct 2019    Post subject: Reply with quote
Well the tank is pretty much brand new. i've got the sucker in a gokart we've been building for dirt drags, it had the same problem in the bike too, number 1 cyl has 90 PSI as the others have 120 so we're going to try lapping the valve to see if it makes any difference with how #1 fires and I suppose if that doesnt work i'll have to go to the float needles? what do you think?
The last post was made 6 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 127.34 Kb
