Honda CBF600 2009 oil weep
voxy53
PostPosted: 16:25 - 26 Oct 2019    Post subject: Honda CBF600 2009 oil weep Reply with quote
Hi All
I have noticed a slight oil leak coming from the front sprocket area of my bike
I am just about to replace the front and rear sprocket and chain, so I have also bought a new pinion oil seal which I am hoping I can change after taking off the front pinion
Has anyone done this job and if so how did you remove the old oil seal ?
Thanks for any advice
voxy53
redeem ouzzer
PostPosted: 17:07 - 26 Oct 2019    Post subject: Reply with quote
Bike?
Be a REAL MAN!
colink98
PostPosted: 17:30 - 26 Oct 2019    Post subject: Reply with quote
Forced wrote:
Bike?
Honda CBF600 2009
Ride it like you stole it.
Meatybeaty
PostPosted: 17:43 - 26 Oct 2019    Post subject: Reply with quote
Dont think this seal can be done from the outside as the seal has a lip which sits on the inside, but could be wrong
jaffa90
PostPosted: 18:14 - 26 Oct 2019    Post subject: Reply with quote
Are you talking this,
https://www.wemoto.com/bikes/honda/cbf_600_sa8_abs/08/picture/drive___output_shaft_oil_seal
I dart/pierce the oil seal at an angle in the middle more so away from the output shaft and lever against the casing with a lollipop wood stick.
If this fails then i dart 2 holes and use thin self tapping screws or chipboard screws again avoiding the shaft and pull the seal out.
Also check if the engine crank case is breathing.
Islander
PostPosted: 18:17 - 26 Oct 2019    Post subject: Reply with quote
Before you do anything drastic, clean out all of the chain lube and crap that accumulates under the cover and then see if you still have a slight leak.
voxy53
PostPosted: 11:03 - 27 Oct 2019    Post subject: Reply with quote
Hi All
Thanks for your replies
Yes you are correct Meatybeaty
There is a lip on the inner edge of the seal which presumably stops the seal coming out
If I can get the old seal out I suppose I could take the lip off and push the new seal in with some adhesive around the edge !! Not good practice though !!
I haven't taken the sprocket off yet to see whether there is a casting that can be taken off to remove the seal
I can't believe that Honda would require you to split the cases to replace this seal (if it has gone )
voxy53
Meatybeaty
PostPosted: 11:14 - 27 Oct 2019    Post subject: Reply with quote
voxy53 wrote:
Hi All
voxy53
Yes ,unfortunately the lip sits in a groove in the crankcase, on some bikes there used to be a plate with 2 little bolts holding the seal in placed on the out side, I think cutting the lip off wouldn't help as it would work its way out , just to confirm try and get the workshop manual it would explain better, but it could be a split to put it in
Have a look here
https://www.manualslib.com/download/1068381/Honda-Cbf600sa.html
Its USA Manual
Have a look at the Haynes
But as @Islander says first look and clean up
PostPosted: 13:28 - 27 Oct 2019    Post subject: Reply with quote
It's more likely to be accumulated chain lube fling dribbling down than an oil leak. We've been here before with others.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:08 - 27 Oct 2019    Post subject: Reply with quote
A lot of lube with a hot seal (stick it in boiling water for a couple of minutes) and that lip will pop into the gap from the outside no trouble.
Triumph Sprint ST 1050
Robby
Dirty Old Man
PostPosted: 16:51 - 27 Oct 2019    Post subject: Reply with quote
As Islander and Stinkwheel have said, it isn't the seal. It's grease and gunk around the front sprocket, which is melting and dripping down when the engine is hot.
voxy53
PostPosted: 17:46 - 27 Oct 2019    Post subject: Reply with quote
Hi All
Thanks to you all for your useful comments
I think that changing the seal by taking the lip off may be a bad idea !!
I think that the problem IS the grease from the chain melting as some have mentioned, so I will clean the whole area when I take off the front sprocket
Just as an aside, there are no drips from the bike at all on the ground.
I have a bit of work to do over the next couple of weeks
I will be changing the front and rear sprockets and chain ( but not the oil seal !) and have just bought a scottoiler esystem with a twin outlet to lubricate both sides of the chain which should lengthen the life of the chain and sprockets
Has anyone got one of these fitted to their bike and if so are they happy with it ?
Thanks again
voxy53
Nobby the Bastard
Harley Gaydar
PostPosted: 11:41 - 28 Oct 2019    Post subject: Reply with quote
Love my scotoiler but the twin applicator is no good on my bike (single sided swingarm) as it sprays oil on the brake disc.
xX-Alex-Xx
PostPosted: 13:50 - 28 Oct 2019    Post subject: Reply with quote
Thanks again
voxy53
Not had a twin outlet, but the single outlet I had on my 929 was great. Just ran regular gear oil on it, much cheaper than the official Scottoiler lube (but that's a whole other debate) ....
DILLIGAF
The last post was made 6 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 79.01 Kb
